Old 06-29-2020, 10:41 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Grant’s 67 Survivor is just that, no repro gauge cluster here. LOL.
New photo showing his factory paper sticker with black overspray.
It seems Fremont is sloppy with overspray.
The paper sticker looks to be curled up on one side and you can see the “W” and “USA” at the bottom corner.
Chris.
ID:	543790   Click image for larger version
Old 02-17-2023, 04:35 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Default Found Another!
After searching eBay for the past two years, I finally found another like mine. Even though it's a "speed alert" cluster, it has the same outer blue housing and appears to be dated Jun 13 1967, around the same time my car was built.
https://www.ebay.com/itm/265932918149
The Following 2 Users Say Thank You to 428ho4spd For This Useful Post:
Old 02-20-2023, 11:25 AM
GTOh!'s Avatar
GTOh! GTOh! is offline
FWIW, here's another photo of the rear cluster.
This one is from my original 05C (3rd week in May '67) cluster. I took this pic while I had the dash out to replace the heater fan switch, gauge light bulbs and gauge lens.
Hope this helps.
Don
Name:	Cluster - REAR.jpg
Old 02-20-2023, 11:44 AM
428ho4spd's Avatar
Hope this helps.
Don
Yes, that's how they "normally" look, just natural metal. When I first noticed mine while working under the dash a couple years back, I knew it was something I'd never seen before. The same blue used on the inside of all housings was also painted on the outside on mine.
ID:	607553   Click image for larger version
