Old 09-14-2020, 07:45 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Compushift has definable values, the USShift has pre-programmed 'modes', so you generally have to pick a 'mode' and make limited changes to it.
The CompuShift has fields you can actually input values into, not pre-programmed stuff.
Or that at least how I saw it, could be mistaken, it's been about 3-4 mo that I looked at the data, and my comments were consolidated ones from that previous research, if you get what I mean.
I've never physically held a USShift unit in my hand, or set one up, so that would have to be taken into account.
I don't see a 'burnout' mode as being any great benefit, you can manage a burnout when the trans program is 'right' without any 'feature'. If you want more line psi for a burnout, you set it. Done. In general, you can 'drive' on that 'program' without any difficulty, if you catch my drift.
I can't see where locking up the converter for a burnout has any benefit, and that's the only thing I can think of that might be of value for a burnout. And you generally wouldn't lock up in 1st or 2nd gear in normal driving.
Maybe I'm not understanding the feature, but regardless, the CompuShift is considerably more expensive, and you can get around the missing 'management' with the USShift unit.
The controller ignores the upshift command while in the box. This prevents a shift while doing a burnout.
Old 09-14-2020, 09:31 PM
Formulajones's Avatar
I do mine in 3rd anyway so I don't really see a need for that feature. I may do the transbrake that is offered though since I have a 2 step.
https://youtu.be/XqEydRRRwqE
Old 09-15-2020, 08:37 AM
Gary H's Avatar
Gary H Gary H is offline
Originally Posted by DarcyL View Post
Great info, GaryH do you like the TCI unit? would you choose one again? I have been leaning toward that unit, as I like the display size, and that you can monitor trans temp with it easily.
Yes, I would choose the TCI unit again. The main issue I ran into is that it initially would not shift gears when I did a full throttle blast (scary). Normal driving it shifted fine. In speaking with TCI they said that when you hit full throttle the controller uses the RPM to determine the shift points, which you program in the controller. For some reason the controller wasn't getting the signal from the distributor as to what the RPM was. It would only loose the signal at high RPM. The solution was to bypass the TCI tach filter and it worked perfectly after that.
Old 09-15-2020, 10:18 AM
Hmm You'd think it would use the speed sensor, and a combination of gear and tire height. That's how HPtuner worked for the transmission controls on the OEM stuff.
I'd honestly rather not use the tach signal for a trans controller. But if that's the way they all are I guess you're stuck with it.
Old 09-15-2020, 11:05 AM
HWYSTR455's Avatar
The way the CompuShift and Holley Dominator ECU work is it stays in whatever gear you have the selector in when in anything other than OD (4th).
Old 09-15-2020, 12:01 PM
Yes that's how Hughes explained it to me. So you actually have full manual control with the shifter if you wish, or you can leave it in overdrive and let the computer take over.
So I can be in the burnout box, start in 1st, manually shift to 3rd and finish the burnout. Then click in overdrive for the pass and let the computer take over the shift points. Which makes for a really nice setup.
Plus their transbrake also still allows full computer control and no reverse pattern necessary. It's a pretty slick deal all around.
Old 09-15-2020, 05:56 PM
quicksilver97ta's Avatar
Baumann electronics. I believe I have an earlier US shift called an Optishift. I bought the whole set up a few years ago from Jake as well. Happy camper so far. One thing I haven't seen mentioned or perhaps I missed, is that you can toggle between two shift calibrations. So I have one set up with slightly higher shift points than the other.
Old 09-15-2020, 07:57 PM
ponjohn's Avatar
Interesting.
Have you compared a fully automatic pass vs. manually shifted?
Old 09-15-2020, 09:48 PM
Interesting.
I have with 4L60E's and there is no discernable difference. Actually the runs were more consistent and quicker with the computer taking control because it took human error out of it. That's the neat thing about the E trans, I can precisely choose the shift points needed down to double digit rpms, and it would duplicate it every time without the need to even watch the tach once you have it where you want it, and I can then concentrate on cutting a light and pointing the car.
I'm sure the 4L80E wouldn't be any different and that's one of the big attractions of it for me.
Honestly though, once you have the parameters you want programmed, and have the trans shifting exactly the way you want, with both upshifts and downshifts occurring where you want them when you whack the throttle, I rarely find the need to ever move the shifter out of OD. While all that can also be done with a TH400 governor, that process is extremely time consuming, messy, and I usually go through a couple gallons of trans fluid and a few days of my time before I eventually get the trans doing what I want for a particular engine. With an "E" trans you just push a few buttons, and it can be done on the fly as well.
Old 09-16-2020, 08:41 AM
HWYSTR455's Avatar
What is better is to config shift points and psi based on TPS, then, you only need one 'profile' or config.
And remember, you can always still shift with the selector and control your shift points.
Old 09-16-2020, 07:25 PM
ponjohn's Avatar
Correction: US Shift Quick 6 is not designed to work with the 4 speed autos, so therefore no electronic T-Brake available.
Old 09-17-2020, 03:10 PM
DarcyL DarcyL is offline
Decided to go with the Compushift- We'll see how it goes! Thanks for all the input.
The Following User Says Thank You to DarcyL For This Useful Post:
Old 09-18-2020, 10:48 AM
That's what I'm going to use on the 4L80E. Let us all know how you like it.
Old 09-19-2020, 04:25 PM
Will do- I'm just finishing some house reno's before the snow comes, then I'll assemble the trans and get it in the car- probably won't have any news till spring-
