The only 'switched' black w/yellow wires I'm seeing is wipers, washer and TH400 downshift switch.
Clay |
I think you're on to something Clay.
Mike can you check the wiper motor for a Black with Red stripe wire? If its there, try switching with the Black with Yellow stripe wire on the relay and see what happens.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express 2024 Cadillac LYRIQ |
I re-routed some of the wiring years ago, like my regulator. It possible that when I re-wrapped it, I wrapped that plug. I'm going to start by removing the harness plug and see if I even see an orange wire. If not, I'm running a hot wire to the relay.
- Mike '69 Firebird 400 - Goldenrod Yellow, 455 +.060, '6s-7' heads, Comp Cam 276AH-10 (51-309-4), TH400, Ford 9-inch w/3.08, 800cfm Q-jet, Stock Intake, Hooker Headers, Flowmasters '68 Coronet 500 Convertible - Medium Gold Metallic, stock 318 +100,000 miles |
Most likely the one I currently have on the relay is the downshift plug. The car is far from stock and never had a stock downshift.
Do your initial key buzzer testing at the turn signal switch connector. That's if it doesn't start working when you get a hot wire ran to the relay. No since in pulling the steering wheel if you don't need to. Clay |
Here's some pics I added some 'commentary' to:
and inside of car: The orange wire is not the source of power to horn relay, it's the one to the alternator wiring loom by the fusible link connection. The dark green on engine side from relay to firewall becomes black out of the firewall connector that goes to the steering column connector. I would think the dark green would not have any other wire with it? (like your pic) The black single pink stripe is the buzzer. You need a black single red stripe probably a bigger wire for power to the relay. (should be from the alternator wiring loom on engine)
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates Last edited by johnta1; 10-26-2020 at 08:47 AM. Reason: added updated pic |
I decided to just add a "jumper" from the alternator to the relay. Horn blows any time. The buzzer does not, as I expected. Pulled the wheel and the buzzer/key switch is broken.
Good to see you found the problem possibly. (at least one of them)
