Old 10-19-2020, 09:17 PM
PontiacJim1959 PontiacJim1959 is offline
If the clutch rod pins are that worn out, then it is most likely that the hole on the clutch pedal that it goes into is also worn/elongated. I welded mine up and redrilled it.
On my '68 I used the factory push rod, but cut off the worn ends, threaded the rod's ends, and added heim joints.
I also added Shell Needle Roller Bearing to my clutch pedals to replace the factory steel spacer sleeves.
ID:	551810   Click image for larger version
ID:	551811   Click image for larger version
Old 10-19-2020, 11:33 PM
Singleton Singleton is offline
Tell me more about this shell bearing modification. Have a part # for them?
66 GTO, 495, M22, Strange S-60 w/4.10
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
Old 10-20-2020, 08:42 AM
HWYSTR455's Avatar
Ditto, but thinking one could use roller pilot bearings maybe?
Old 10-20-2020, 10:16 AM
Formulajones's Avatar
They've had them for mustangs for years. Not overly expensive either
https://www.summitracing.com/parts/sdk-c5zz2478rbmk
I've installed these on a Mustang, but these same kits I'm told are also used on GM as well with a little ingenuity.
https://youtu.be/XqEydRRRwqE
Old 10-20-2020, 10:19 AM
BTW, for anyone wanting to make their own clutch rods, or manual trans shifter rods etc. Easiest way is .500” mild steel tubing, .095 wall, which has a .310 ID. This ID is the right size for a 3/8 24 tap, so no drilling required.
Just need a R/H and L/H 3/8-24 tap and the appropriate left and right rod ends, (which are pretty cheap at $5 ea). The clutch fork from Speedway is $39.95.
https://www.speedwaymotors.com/Speed...ork,37080.html
70 Formula 400/auto
Old 10-20-2020, 08:27 PM
Here you go, this is my complete write-up on the upgrades which includes my parts list and photos. Have yet to install or see if this is going to work in actual use, but it seemed like an upgrade to me that will hopefully work in practice.
https://www.gtoforum.com/threads/clu...0/#post-893341
The Following User Says Thank You to PontiacJim1959 For This Useful Post:
Old 10-19-2020, 09:37 PM
Tom Vaught's Avatar
Boost Engineer
Some really nice fabrication work there, PontiacJim1959
Tom V.
Old 10-20-2020, 12:20 AM
4zpeed's Avatar
4zpeed 4zpeed is offline
Tom V.
I agree.
In addition if the bushings on the peddle shaft are maintained along with the bellcrank bushings there is much less wear in the pin hole areas due to absorption.
Holes get elongated and pins get worn because bushings aren't serviced either due to neglect or the fact they are overlooked, maybe even not known to a previous owner to exist.
With those bushings worn out, possibly even gone, it puts allot of extra pressure on the entire clutch linkage and can take significantly more pressure to activate the clutch.
Frank.
Poncho Huggen, Gear Snatchen, Posi Piro.
Old 10-20-2020, 07:51 AM
chrisp chrisp is offline
Originally Posted by 4zpeed View Post
I agree.
Frank.
I have flanged bushings to fix the egg holes / bronze 5/16 i.d. ,if in need.
The Following User Says Thank You to chrisp For This Useful Post:
Old 10-20-2020, 12:02 PM
4zpeed's Avatar
My factory GM set up is good to go in the GTO.
Tanx for posting though as others may be in need.
Frank
Old 10-20-2020, 12:12 PM
Formulas's Avatar
Formulas Formulas is offline
My 70 Bird bell crank was tougher than the linkage pins it didn't elongate I just got 2 new stock linkages the hole in the pedal arm was elongated I welded it shut and re'drilled not at all to difficult and it was like day one again
But being a retired aircraft technician I might go spherical rod ends someday for the halibut but it's not to urgent
........... The More You Follow The Herd The Less You Can Be In The Lead ..........
Old 10-20-2020, 12:28 PM
Tom Vaught's Avatar
Boost Engineer
Same deal with my original Z-Bar. The Z-Bar was fine, the Threaded rod end (square) that threads on the clutch rod was worn badly where the hair pinned pivot went thru the Z-Bar.
I did change that to the heim joints that attached there and at the corvette fork.
I left the stock stuff inside the car that attached to the other end of the Z-bar as it was fine.
I did all of these mods over 35 years ago.
Tom V.
