I'm chiming in here incase this interests anyone;
For a LONG time, I had scavenged for original parts, and somewhere along the line I got a really nice looking side post negative cable; It has an extra ground wire, and is stamped with the following: 8915800 DT It appears to be approximately 25" long. Knowing the types of vehicles I scrounged parts off of, I would have to think this is an original Pontiac application part.
1970 Formula 400 Carousel Red paint on Black standard interior A no-engine, no-transmission, no-wheel option car. Quite likely one of few '70 Muncie three speed Formula 400's left. 1991 Grand Am: 14.4 @ 93.7mph (DA corrected) (retired DD, stock appearing) 2009 Cobalt SS: 13.9 @ 103mph (current DD; makes something north of 300hp & 350ft/lbs) Last edited by unruhjonny; 12-02-2020 at 12:17 PM. |
Mike, that is kinda funny. I understand the electrical circuit logic but seriously? GM couldn't source enough 30A fuses??!!
Curious that the repair relates to the A/C application. Since the 30A inline fuse was used with and without A/C, did A/C tend to overload the circuit while the non-A/C did not? Just curious why that would be. unruhjonny, that cable might have had other GM usage, I sure don't know. But googled it and found this indicating it was the OE negative cable for the '77 Cutlass. https://classicoldsmobile.com/forums...-wanted-58143/ Couldn't find anything more on it at GMPartsWiki. Similar to the one I have with the LG pick code, the DT pick code seems to identify cables that were OE to whatever application (wasn't able to identify any particular application for the one I have) while the Service Replacement cables seem to lack a pick code, which makes sense because the pick code was only useful during Final Assembly, didn't have any use for Service Replacement parts. |
It may have easier to tell a customer that it was out of stock and the new replacement was this...
I can't comment on the poor connections when it came to AC. May have to do with the current draw when it starts up, much like an air compressors' initial start up.
So long, farewell. |
