Old 11-17-2020, 10:52 PM
David Holmberg's Avatar
Congrats!
Old 11-19-2020, 04:14 PM
Old Goat Racer's Avatar
Originally Posted by firechickenman View Post
I had an opportunity yesterday to make a few passes in some great fall air and was able to check off some goals I'd had for a while. I was looking to get to 1.39, 6.39, 9.99 and 135. It wasn't easy as it was a test n tune/fun drags day with quite a few cars running regular street tires so the starting line was kinda hit and miss. On pass number 6, I finally got it to stick and all my goals were covered!
It went 1.37, 6.30, 9.93, and 135.14!
In car GoPro: https://youtu.be/k9j-Lxh0bW8
It appears are goals are similar .
Everybody knows somthin.
Nobody knows everything !
Old 11-19-2020, 10:53 PM
firechickenman's Avatar
firechickenman firechickenman is offline
Congrats! I was a little faster, but you beat me to the stripe with your superior reaction time!
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/[email protected]/[email protected]
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69 - Quickest Pontiac
2022 - 10.13 @ 133.07
2025 - [email protected] - 2nd place SRBBNA
Old 11-20-2020, 12:04 PM
My MPH seems a little slow ? Think'in my holley blue might be a little short on gas.
Old 11-22-2020, 08:40 PM
Actually, your numbers are more in line with the "ideal times" using the calculator on Wallace Racing's website based on our 1/4 mile ET's.
http://www.wallaceracing.com/etcalc.php
Also, I've made a video of all my runs that day for anyone that has 5 minutes to kill... https://youtu.be/1i1TwcL28Mo
Greg Weigart
Old 11-23-2020, 02:47 AM
Scott Roberts Scott Roberts is offline
Looks like u hurt everyone's feelings that day.. raggedy old Pontiac...
Old 11-23-2020, 10:48 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Were you changing shift points etc to get sub 10?
Old 11-23-2020, 01:08 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Yikes, that’s moving!
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 11-23-2020, 01:15 PM
Hmmm. Food for thought. Thanks, OGR
Old 11-23-2020, 02:01 PM
AG's Avatar
AG AG is offline
Do you have a rollbar?
Old 11-23-2020, 02:10 PM
Same tune, same shift points. I just tweaked the shocks and tire pressure a little trying to get it to hook. The air got better throughout the day and the wind calmed down. I also took out everything that wasn't bolted down....and maybe a couple things that were!
8 point since 2013.....wishing it was a 10 point cage now!
Greg Weigart
Old 11-23-2020, 04:20 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Congrats!
I am trying do do the same with the Camaro/IA. Yesterday small test and tune track rental best I got was 10.44 @ 130.8 and only a 1.53 60ft. New convertor I thought would help a little higher flash but not there.
Freaking new Dodge Demon in the pits next to me low 9s @ 140+(and no cage or chute) and has freaking A/C!
Skip Fix
Old 11-23-2020, 06:26 PM
Firechickenman are u using a t-brake ? My car has one but I'm "old school" footbraker. My car barely lifts the left front wheel.
Old 11-24-2020, 02:27 PM
Originally Posted by Skip Fix View Post
Congrats!
You'll get there with some more track time and tuning. There should be a least a tenth to be had in the 60' which makes a bigger difference down track.
I'm a footbraker too. I don't get much air either. I think the footbrake and my 3.73 gears might have something to do with that.
Greg Weigart
Old 11-24-2020, 06:36 PM
Skip Fix's Avatar
You and Darby are giving me goals to shoot for.
Old convertor and a little better air 10.30s @ 132. Something in either convertor or trans just not getting the 60 ft as I'm not even spinning. Starting to lean towards trans as 3 different convertor have not made much difference. I'm just at a loss.
Skip Fix
Old 11-24-2020, 08:47 PM
Don't remember how your car suspension etc is setup as, but when I started making more power, it leveled off until I stiffened things up.
Welding the subframe connectors in helped a lot quicker ET.
Welding a cross brace connecting the axles tubes and middle section added quicker ET also, surprisingly. Changing to ladder bars instead of leaf springs added quite a bit.
Narrowing rear subframe and rear end making it stiffer with a cage added even more quicker ET.
Fine tuning all the adjustments on chassis setup added quicker ET
No extra HP added.
Old 11-25-2020, 02:46 PM
What RPM are these converters flashing to? My old 10" would go to 4000 and my 60' was in the mid 1.50 range. A different 10" that goes to 5000 got me into the mid/high 1.40's. That was with my old 254/260 112 LSA cam. I still have the same converter in it now and it works well with my 266/272 110 LSA cam. Typical 60' on a good track in the heat is in the low 1.40's
Greg Weigart
  #38
Old 11-26-2020, 10:34 AM
Skip Fix's Avatar
Trying to tell on the data recorder form the graph what the actual flash is. When the car starts moving or at the top of the rapid slope. I think this new one is close to 5000. Some graphs. Slippage about 12-13%
Some strange things with trans intermittently. I'm leaning toward that as a potential issue. Rarely doing a burnout revs but tires do not spin, and rarely hit 2-3 and like it goes into neutral. It was built with a locked out governor(big spring like deal over the weights) to make it a manual shift. Starting in second it really does not like to even move easily.Not sure if burnouts is between 1&2 acting like a trans brake and in between gears. Other times perfect.
Name:	Baytown 3 launch movement rpm.jpg
ID:	554793   Click image for larger version
Name:	Baytown 3 launch ramp rpm.jpg
ID:	554794   Click image for larger version
Name:	Baytown 3 top end rpm.jpg
Skip Fix
  #39
Old 08-06-2021, 03:49 PM
69Goat1's Avatar
69Goat1 69Goat1 is offline
Flying!
Sent from my iPad using Tapatalk
1969 GTO, 5.77 @ 121 1/8th mile 3450 lbs...535 with Junk dinosaur Eheads
Faster on nitrous…
