Old 12-02-2020, 03:44 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
badass.. I have a 70 bonneville 2 door that dreams of being this cool!
Old 12-02-2020, 08:27 PM
Scott Roberts Scott Roberts is offline
Don't paint it.. take a hammer and knock some dents in it, put 2 different front wheels on it, ad the quietest mufflers u can find ( I've used 4 in the past) and go make some money.. only ever win by a fender...
Like my old friend Joe B used to say when asked how fast it was.. " just as fast as it needs to be"...
Old 12-02-2020, 08:34 PM
oethel's Avatar
oethel oethel is offline
I like how you think 🤐
Old 12-02-2020, 09:06 PM
charlie66's Avatar
Cool im glad it worked out for you . Do you have any intentions of turning up the boost?
My Half AN Injun.....
Old 12-02-2020, 11:14 PM
oethel's Avatar
Ultimate goal is a 5 second run.I want to do it on the lowest boost i can.I'm going to optimize several things and then if I have to add a few pounds boost I will.That 6.59 run was only the 10th hit at the track over a three or 4 week period.I changed jets,pvcr's,adjusted both of my brpv's,timing,closed my spark plug gap a little,changed wastegate springs and added Sunoco 110 at higher boost.I started at 7lbs and watched my plugs and AFR and worked my way up.If your on facebook Roscoe Woosley Sr has a video of the 6.59 run on Nov.7th
