Old 12-09-2020, 10:34 PM
joes455 joes455 is offline
I read the drum brake assy is like 30lbs heavier than the 60
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 12-09-2020, 10:44 PM
73 TRANSAM 73 TRANSAM is offline
If running a Dana 60, a Wilwood Pro street rear brakes will be a lighter option.
The Following 2 Users Say Thank You to 73 TRANSAM For This Useful Post:
Old 12-09-2020, 11:06 PM
69FIREBIRD76MM's Avatar
Default Dana 60
Originally Posted by 73 TRANSAM View Post
The downfall of a Dana 60 is u can only get down to 3.54 gears unlike a 9 inch. But for strength of a posi unit the Dana 60 is hands down stronger. I am running a Tru trac on my street Dana and they must have weigh 40+ lbs for that differential. The 9 inch's diff is not going to be as beefy for sure. But with a spool then a 9 inch will shine. More option and easier to service.
Guy on eBay selling 3.23 gears for the Dana 60, I think his name is "Dr. Differential". I bought a set for me.
The Following 2 Users Say Thank You to 69FIREBIRD76MM For This Useful Post:
Old 12-10-2020, 01:59 AM
Thanks for the info on the 3.23 gears. Just bought one for my race S60. Need to lessen the hit off the line.
Old 12-10-2020, 09:30 AM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
For factory stuff they make more highway friendy gears for what's considered a Dana 61, buts that more for late model stuff that's changes the pinion position to allow for a highway gear. But I don't believe those will transfer into a 60.
I bought my 2 dana 60 for 100, so it was a pretty easy choice to go that route. I don't think your going to get 12 bolts that cheap. And the Explorer dics brakes are a nice cheap alternative .
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 12-10-2020, 09:54 AM
Half-Inch Stud's Avatar
My S60 is a good thing now that the OVERDRIVE is in front. 455+ OD is a very big upgrade.
Disc setup: 79 Rotors (drilled for Half-Inch x 5" pattern & ID ground for Axle hub), 82-84 Trans-Am Calipers and Bracket Backing Plates (honed for S60 Flange, and Emergency cable.
Been "no maintenance" except for switching from 80/90w to Redline synth Shockproof.
Old 12-10-2020, 10:39 AM
Rob B's Avatar
Rob B Rob B is offline
When I had a rear end built for my 74 GTO, I had Moser do it and went with the Dana 60. From what they told me, the weight difference between the 12 bolt, 9 inch, and Dana was a wash and it just depends on what options you add or don't add to the build, maybe 20-25lbs over a 12 bolt. the Dana requires the least amount of HP to spin plus it allows for up to a 40 spline axle and I wanted something that was overkill so I don't have to mess with it. 8 yrs laters, not one issue. Had Moser do a 12 bolt 2 yrs prior for the wife's cars (similar builds) and its gonna need a gear, getting a little noisy when coasting. Hers has a lot of street/hwy miles on it so not surprised at this point. You really can't beat the simplicity of just calling them up and having them build brand new what you want and just go and pick it up, and the pricing really isn't bad either considering.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
The Following 2 Users Say Thank You to Rob B For This Useful Post:
Old 12-10-2020, 11:16 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
One of my Mopar buddies swapped in a Strange 60 and said they are easier to set up than old 60s as they have a side adjustment liek a 9" or other pumpkin rears to slied the ring gear back and forth vs strictly shims.
Skip Fix
Old 12-10-2020, 06:20 PM
Dragncar Dragncar is offline
MW makes a "drop in" center section for a 9" that is a 12 bolt ring and pinion. If you want every last bit of power.
Old 12-11-2020, 01:38 PM
bankbook's Avatar
bankbook bankbook is offline
Been running 60 since mid eighties. First by chance that a buddy had one after wrecking a Cuda.
This ones been in for a long time and love it. Only downside to Turbo app is that you can not get numerically lower than a 3:54.
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
The Following User Says Thank You to bankbook For This Useful Post:
Old 12-11-2020, 02:49 PM
Dana 60 3.23 is available, thanks to 69Firebird76mm link that he shared. I ordered one myself for my race S60.
The Following User Says Thank You to 73 TRANSAM For This Useful Post:
Old 12-11-2020, 05:40 PM
JSPONT's Avatar
JSPONT JSPONT is offline
I have been running a spooled S60 for years in my heavy turbo'd Lemans no issues. Willwood rear disc brakes, The S60 as stated is set up better for adjustment than the old Dana's. When I was looking 3:23's were on a backorder, I have 3:54's on a 28 inch tire, not to bad on the highway.
Old 12-11-2020, 08:36 PM
Default Dana 60
https://www.ebay.com/vod/FetchOrderD...=2234803677007
Link to New Dana 60 3.23 by Dr. Differential if anyone needs them, he is got 1 more set left.
I did some research there was 3.08 and 3.31 ring and pinion for Dana 60, they are just very hard to find.
The Following User Says Thank You to 69FIREBIRD76MM For This Useful Post:
Old 12-12-2020, 03:17 PM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
Mine is old school with the 57/64 rear with Fabcraft upgrades and MW spool and axles. But I was trying to keep period correct. Not sure what it weighs but it’s dang sure strong
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
The Following User Says Thank You to jimmy daniel For This Useful Post:
Old 12-13-2020, 09:56 PM
ScottK. ScottK. is offline
Just my 2 cents but why not pull a Ford 8.8 out of a Ford Explorer they are every bit as strong and some would argue stronger than a GM 12 bolt and disc brakes are free.You can pick these up for under $200 and there everywhere.All you have to do is cut the long side axle tube out of another donor I paid $25.00 for the extra tube and don’t forget to grab the long side axle as well.There is only a 1/2 inch difference (longer) on each side.Just throwing this out there but there well known to handle 1000 horsepower people do it all the time.
ID:	556124   Click image for larger version
ID:	556125   Click image for larger version
Old 12-14-2020, 08:59 AM
JoePapa's Avatar
JoePapa JoePapa is offline
This is another site to consider for sourcing a custom rearend. http://www.dtscustom.com/
I've got the dana60 on my '69 and a friend has a shortened version on his '79. No issues and no breakage since.
'69 Firebird 400
http://firstgenfirebird.org/show/closeup.mv?CarID=734
Old 12-14-2020, 09:20 AM
I chased the 3.08:1 gearset capability into the tumbleweeds. If available these days i would strongly consider going back to the TH400! Selling the 4L80 setup would cover that gearset cost. Show me the 3.08:1 !
  #38
Old 12-14-2020, 11:03 AM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
Only place I saw tall gears in a Dana 60 were the early 70s ambulances.
Clutch Guys Matter
_______________________________________
53 Studebaker, 400 pontiac
72 4-4-2 Mondello's VO Twister II
1964 F-85 Home of the 700hp small-block Olds
**Still wanting a 64 Bonneville or Catalina**
  #39
Old 12-14-2020, 11:09 AM
In higher hp levels I would switch to the big bearing new style 9" ends and keep the original disc brakes instead of c clip eliminators which I don't believe they even make for an explorer rear end. . But anyway they work good on my Dana 60. All else that's needed are the spacer rings for the thickness of the backing plate.
6.27@107
9.97@131
  #40
Old 12-14-2020, 08:50 PM
Tom Vaught's Avatar
Boost Engineer
I have never had ONE issue with my Strange Center Section 9" Ford,(with a reinforced housing and Torino Housing Ends and Explorer Rear Disc Brakes).
That being said a friend in the 70s got tired of breaking Pontiac Big Car Rears in his 63 Tempest Super Duty Car and installed a Dana axle under that car and my understanding is it is still working since the 1970s.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post:
