Old 05-31-2021, 11:40 AM
justincampbell's Avatar
justincampbell justincampbell is offline
Originally Posted by SRR View Post
Been 3 weeks, any updates?
No updates yet. Been pretty busy with the usual spring/early summer chores and trying to get a '38 Ford up and going. Between those things and the fact that the truck runs like a champ when not pulling a load for a distance(which I only do once or twice a year) I just haven't done much with it.
"What the hell's wrong with freedom man? That's what it's all about." (Billy)
"Oh yeah, that's what it's all about alright... but talkin about it and bein it, that's two different things." (George)
Easyrider
Old 06-01-2021, 03:17 AM
59safaricat 59safaricat is offline
AOD transmissions don't have torque converter clutch, it's shaft operated.
https://www.youtube.com/watch?v=HGptqCo65LE
Old 08-10-2023, 03:09 PM
Still fighting this darn thing when I put some miles on. It has gotten slowly worse. Now it does this whenever I put a lot of miles on. When it is doing this garbage and I remove the fuel cap you can hear the pressure change significantly... sometimes the fuel vapor coming out even makes the side of the truck wet. FYI I checked it with a couple different fuel caps and that had no bearing on things. I have replaced almost all the cheap/easy parts that have been suggested to me with no real improvement. I replaced the throttle position sensor, the MAP sensor, the fuel pressure regulator and I block the EGR. FYI, I did each of these separately so as to determine if any individual part was the problem. Pretty sure vapor lock is an issue. Now, I just need to determine if that is a symptom or the cause of my troubles.
The only things I can think of that haven't been replaced are the fuel filter or fuel pump. I suppose it could possibly be the valve for switching tanks? I don't ever switch tanks, but maybe it could still cause a problem with the flow of fuel?
Easyrider
