Many factors come into play to answer that exh to intake ratio question, like Cam specs, compression ratio, but two main things are the motors fast piston speed due to its stroke and if your racing and running open headers with a well set up tuned collector lenght, and especially if there merge collectors making a lot of vacuum at overlap.
Many times there’s no substitute to find out what the motor wants but for pure empirical testing back to back at the race track on the same day.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 08-02-2021 at 07:02 AM. |
Once I get on a decent track..I will be testing 2 carbs and at least 3 different spacers..possibly a few more.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
| The Following User Says Thank You to ta man For This Useful Post: | ||
Throttle body and plenum area.
Switching from a carburetor to fuel injection with a four hole throttle body and and direct port injectors. On the dyno with the carb it liked a 2" open spacer the best. Any reason it would change with the swap? https://www.yellowbullet.com/threads...-area.2627101/ ( Information provided in this post does not represent any endorsement and it is not based on personal experience and is offered for general interest only. Not Pontiac specific with a Torker II intake ! ) .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 08-03-2021 at 11:13 AM. |
I can confirm the 4-hole spacer whistle-fix. I have an edelbrock performer , and with an open edelbrock heat insulator gasket 1/4" thick there was a loud whistle under part throttle, i bougth a 3/16" (i think) 4 hole spacer and that solved all the noise problems.
Murphy's law - "Anything that can go wrong will go wrong". -469 ,Butler 310+ Eheads, Hurricane intake portmatched by butler, Butler roller 230/236 @0.50 112 LSA, Johnson lifters, pypes 2 1/2" exhaust, 3.42 yukon duragrip lsd, holley sniper efi, hyperfuel efi tank +++ Last edited by djustice; 08-03-2021 at 09:10 AM. Reason: cant spell even for love or money :/ |
| The Following User Says Thank You to djustice For This Useful Post: | ||
Even the very old NASH 4 BBL manifolds liked a spacer above the plenum.
And some added Plenum Volume on engines larger than the 366 CID by enlarging the Bottom of the intake plenum by dropping the floor of the plenum. Most "hid" that modification in the old days on their 455 type engines and had "cover plates" over the runners so you could not see the plenum mods. Tom V.
Carb metered and made more power with the spacer because the fuel charge was BOTH "more even" to all of the cylinders but also because the proper amount of air was able to to the intake runner requesting it in the time allowed.
EFI systems like large plenum volumes to the runners. Look at a Marcella manifold or a Hogan manifold. LARGE PLENUM AREAS Tom V.
| The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
With the custom fabricated intake style like those from Hogan that large plenum allows individual runners to have the same cross section, length and all with a straight shot into the heads. Much different that a Torker II intake that has only four of it's runner lengths the same. And the Torker II has only two of it's runners with the same amount volume (cc).
With direct port fuel injection it has been stated one of the advantages of having a dry plenum and runners is that they can twist and turn more sharply to equalize airflow between cylinders without disrupting the air/fuel mixture. Does that apply with the Torker II intake ? Edit: The statement here about the Hogan intake style was an assumption on my part. Tom, correct me if it does not apply.
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 08-03-2021 at 04:04 PM. |
"EFI throttle-bodies are different than carburetors because they don't need a "signal" to get the air/fuel charge moving. And in a port EFI system, the intake is dry; there's no fuel through the throttle-body or intake runners to fall out of suspension. But there's still the issue of total system volume versus engine airflow requirements, so in that sense spacers could still prove to be of benefit on EFI setups, although less so than in a traditional carbureted application."
Source: How Carburetor Spacers Affect Performance https://www.motortrend.com/how-to/pi...t-performance/ .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
