Old 02-27-2022, 09:01 PM
er455 er455 is offline
Default Timing retard
[QUOTE=er455;6322493]Hey Curtis how are you pulling timing out ? Thru a msd box ? I have a MSD 6 plus and it will pull up to 10 degrees out , but would you trust that it won’t fail ? Is there a fail safe way to pull timing out for boost ? Thanks
Old 05-15-2022, 01:20 PM
Curtis Slowe Curtis Slowe is offline
[QUOTE=er455;6322494]
Sorry, haven't been on here in a while. I'm using a MSD 6530 box. It allows you to pull timing where you want and at different amounts if you'd like. I drive around on normal timing and dont pull any until 3psi. It also allows me to pull timing at the leave to calm it down some. Not worried about it failing. Anything could fail at any time. Hard to say.
