Thanks for sharing! Sent from my iPhone using Tapatalk
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone. The frogs take up where they left off. |
nice numbers for sure... what are some other specs if you care to share? heads proted? intake/carb? & why only 9.5:1 with alum heads?
Napster what rocker ratio are you using? I'm guessing more than 1.5s which would only give you .520/.540 lift. GREAT power numbers from that cam
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
I run that cam in my HO. It is cold blooded till warmed up. Makes lots of power. Run with forged pistons 10 to 1, and forged rods. Run RA exhaust. I believe with good headers another 50hp is there.
72 Bird |
I use the car like all my cars. Mostly to and from car shows or take it out for a drive for exercise purposes. Sometimes for a trip, but that is few and far in between. Manners? It is a beast when I put my foot into it. Since I'm breaking it in that has only been no more than 1/4 throttle. Throttle response in right away with the EFI on the car. It is very streetable as long as restraint is exercised. When I first got the car back I wasn't ready for the torque hit and almost overrun the car I was passing. The way the transmission is setup it will go right to the sweet spot of torque when the transmission downshifts. The sweet spot is 4000 RPM. |
Thanks. Running 1.65 ratio roller rockers.
The Following User Says Thank You to napster For This Useful Post: | ||
can you mention some of the specs of your build? curious how it reached almost 600hp & 620+tq with the parts listed & low compression... & why only 9.5:1 with alum heads?
also, since you stated exact hp & tq numbers, i assume it was dyno'd... if thats the case its pretty much as broken in as it will get, at least for ring seating etc. during dyno pulls, it was subjected to far greater forces than it will ever see on the street, you can definitely go more than 1/4 throttle with no risk of damage. |
Other auto brands and false " HP mentality" lead to desktop dynos and open wallets, and a happiness that doesn't last. But yeah, ya got a piece of paper from a dyno which can only calculate HP, not measure it, and from a range starting at 3800 rpms and just skip where Pontiacs Pull, AND where you drive your car, the torque band. I would ask do you want to drag race a road race car, or Just play with power? In the end, Driveability determines if your car gets used, or sits. Imagine how good 400 ft lbs of torque feels at 2400 rpm...
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
