Old 12-19-2021, 07:19 PM
mchell's Avatar
mchell mchell is offline
Wo….pretty darn good!
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 12-20-2021, 03:47 PM
NeighborsComplaint's Avatar
I know you have the dyno sheets prove it but I'll never understand how a low compression motor with low performance Dport heads and a smaller than stock camshaft can make the same horsepower that was claimed on a factory assembled '60s high compression motor with Ram Air heads and manifolds.
Triple Black 1971 GTO
The Following User Says Thank You to NeighborsComplaint For This Useful Post:
Old 12-20-2021, 03:54 PM
Scott Roberts Scott Roberts is offline
I'm gonna say those 60's engines were underrated on hp.. my understanding is that was common practice..
The Following User Says Thank You to Scott Roberts For This Useful Post:
Old 12-20-2021, 04:25 PM
Steve C. Steve C. is offline
The way we measure horsepower has changed ?
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
Old 12-20-2021, 04:59 PM
Tom Vaught's Avatar
Boost Engineer
I WOULD TOTALLY DISAGREE WITH THAT SENTENCE.
I was fortunate to have access to a Clayton Rear Wheel Dynometer at the college down the road from where I lived.
They had a Automotive program there. A/C work, Engine work, Chassis work, some welding classes, etc.
On the Calibrated Clayton Dynometer several vehicles that the Hot Rod Boys owned were tested.
1) A 375 hp advertised 396 1966 Chevelle made 285 rear wheel hp.
285 hp times 1.15 = 327 engine horsepower. the 15% adder is the typical drop from engine to tire hp loss.
The 375 HP rating was probably correct if you tested the engine without the water pump/fan drag and the accessory drag.
(Power steering). Looks Dead Nuts on the money to me.
Tom V.
Old 12-20-2021, 05:31 PM
Tom Vaught's Avatar
Boost Engineer
Measure is the same, How it is Reported is different.
Tom V.
Old 12-20-2021, 05:37 PM
Stan Weiss's Avatar
In a few cases I think they were under rated because of insurance. In most case I think the engine tested by Pontiac was select fitted parts and not a mass produced engines. Don't Royal Oak sell thinner head gaskets to get the CR up? How much farther down the bore are the pistons on a production engine from the blueprint spec?
Stan
Pontiac Pump Gas List
Old 12-20-2021, 05:42 PM
Tom Vaught's Avatar
Boost Engineer
Probably the only engines that could be called under rated would be the 73-74 455SD engines.
Tom V.
Old 12-20-2021, 05:43 PM
Stan Weiss's Avatar
Tom V.
Tom,
Yes, most engine dynos still use the SAE J607. The car manufacture in the early '70s changed SAE J1349. I believe some chassis dynos also use SAE J1349.
Stan
Old 12-20-2021, 05:56 PM
Tom V.
I dont claim to be an expert and have no problem with your disagreement... as state, I was under the understanding that was the case.... I've read ( interweb facts of course) that was the case...
I drove a bonestock 68 bird with a 400 and It sure felt like more than 330ish... seat of the pants kind of thing..
Old 12-20-2021, 06:20 PM
Questions and Answers – Horsepower
https://www.stevelinden.com/blog/que...ers-horsepower
Old 12-20-2021, 06:40 PM
Tom Vaught's Avatar
Boost Engineer
Looks to me like Steve Linden matches everything I posted except for 1m FACT.
The rear wheel HP is not measured at the Axles/"Brakes" unless you take the tires and wheels off the vehicle. Tires do consume horsepower. A thing called rolling friction.
So the driveline has to include the tire contribution.
Emissions people (EPA and CARB) require on the track confirmation testing to assure the Coastdown) numbers used to dial in the dyno rolls matches the actual road measurements. I did Coastdown work for Ford and supplied the data under my name to the EPA as the "Coastdown Test Engineer".
I did the larger Trucks, F-150 thru F-350 vehicles and the Econoline vans.
Other Engineers did the Car platforms and the Small Truck and SUV type vehicles.
If the EPA/CARB was not happy with our numbers, they witnessed a reconfirmation of the track numbers. Most times it was vehicle to vehicle variability and the track numbers were the final numbers used.
So back on the HP numbers, Steve Linden is correct on 98% of his post.
Thanks Steve C for the link.
Tom V.
The AERO Contribution was confirmed at the Lockheed Wind Tunnel at Atlanta Georgia.
Old 12-20-2021, 06:44 PM
steve25 steve25 is offline
25 seconds with a needle nose plier on those early FB 330 hp motors and you did then have more than that amount of HP!
Removing the limiter they had got you the 350 hp motor.
Old 12-20-2021, 06:48 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Either the RAIV was under rated or the RAIII was overrated sine there is no way only 4 HP separated the two.
I remember an old Roger Huntington article where he had the factory dyno curves for some 60's hipo engines. If they wanted to rate conservatively they pull the HP from below peak. For instance the 426 HEMI was rated at 425Hp @ 5000 rpm when it actually peaked closer to 6000 and 470HP.
Factory advertised ratings were just that, advertised.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
The Following User Says Thank You to TCSGTO For This Useful Post:
Old 12-20-2021, 07:11 PM
Same stuff I read... so who's right, Tom or the internet... the internet if full of underrated stories but Tom says thats false... in all caps. I'm going with motor city tom...what could those other guys possibly know.
Old 12-20-2021, 07:14 PM
unruhjonny's Avatar
Either the RAIV was under rated or the RAIII was overrated sine there is no way only 4 HP separated the two. ...
I seem to recall an article from several years ago where these engines were dyno'd and came out nearly nuts on their respective ratings.
I digress, I wanted to comment about something else entirely;
I noticed this:
... W72 400. He rebuilt the original numbers matching engine with .040" over Icon forged pistons w/4.5 cc valve reliefs that are .005" out of the hole and with .045" x 4.328" Felpro head gaskets to provide .040" quench depth. The 6X-4 heads were minimally cut for trueness and measured 92.45 cc's average for an final static compression ration of 8.75 to 1. ...
now, before I say much else, could you tell me if this isn't a PSMCD eligible motor?
Because unless there has been another rule change, the rods alone should disqualify this motor...
Also iirc this engine should have had an advertised compression of 7.6:1, and if I am correct this would be a bump of more than a full point - which should again make it disqualify.
I have not read of any builds here that have the piston out of the hole, most are (if my memory serves me) about 0.020" down so that was interesting for me to read.
I normally read that with the piston down and the thicker fel-pro gasket, that engines like this often yield a marginal drop in compression;
granted the overbore helps kick it back up;
And in this example the reduced cc valve reliefs would help too - I cannot off hand recall the size of the cc valve reliefs in pistons from this period - can someone post this to help me out?
This is pretty cool to see the honest to goodness power that can be made from a very stock appearing motor.
You guys sure do some interesting engine builds!
1970 Formula 400
Old 12-20-2021, 07:21 PM
[/QUOTE]
There is a lot more power to be had in the F.A.S.T class.. stock appearing engines that make big power...
  #38
Old 12-20-2021, 07:23 PM
Folks consider this tid bit.
A 426 Hemi tipped the scales at 843 pounds!!
It needed every spec and more of that 425 hp rating to really beat up on a well tuned RA4 engine!
  #39
Old 12-20-2021, 07:24 PM
Stan Weiss's Avatar
Tom V.
Tom,
This is exactly what they been doing for sometime on high HP cars. They use a hub dyno. It eliminates the tire slippage and give much better results
Stan
  #40
Old 12-20-2021, 07:34 PM
Originally Posted by Stan Weiss View Post
Tom,
Stan
Define "some time"
