Boy when you look over the electrical system in a 68 GTO it's easy to see where about 3 relays would have made the system so much less likely to burn down.
I was just restoring the console harness and wondered about the big thick purple wires to the neutral switch .. yep, it's feeding a huge load from the battery to the neutral switch, to the ignition switch to the solenoid. I noticed the purple wires had seen too much heat, I assume someone laying on the starter for two minutes overheated them. A relay on the firewall and they could have removed six feet of voltage sucking wire and a couple of high current connections. Same with the headlights of course. At least they used one for the blower motor ... but then they also feed all that current through a cheesy speed switch on the dash. I would have much rather had to replace a relay now and then than have critical circuits sending all that juice through a maze of wiring.
I'm World's Best Hyperbolist !! |
| The Following User Says Thank You to dataway For This Useful Post: | ||
