Old 04-21-2022, 09:42 PM
Tom Vaught's Avatar
Boost Engineer
Originally Posted by Rar_421 View Post
Had no idea Tom was involved with Pontiac projects,he was very well known for his work with Kohler snowmobile race engines with Rupp and the Kalamazoo Kyotee sno pro sleds,I've been collecting parts to build a Kalamazoo Kyotee replica
He ever take you for a ride in his 1000 hp chevy Pontoon Boat??
Tom V.
Old 05-04-2022, 05:29 AM
spectramitch's Avatar
spectramitch spectramitch is offline
The dowels in the block are .308 DIA and the New billet caps came reamed already to .312. The new caps should just drop on with slop, they do not. It seems like the spacing between dowels on PMD is not the same as the billet. Has anyone encountered this? It sounds like I need to re-establish location with a mill cutter and maybe open up to 3/8" dowel and not just re-ream the block holes.
Old 05-04-2022, 06:36 AM
krisr's Avatar
krisr krisr is offline
I will add, when drilling or taping stainless steel, use Elmer's glue as a lube. Just the plain old white glue! Sounds crazy, works beautifully. I don't know why. Friend who owns a sheet metal shop showed me that.
I've never heard of using Elmers for a tapping lubricant in SS! I'm guessing you see much more tap life with it?
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120
'66 Pontiac GTO - 389, 4 speed street cruiser
Old 05-04-2022, 09:10 AM
mgarblik mgarblik is offline
The biggest difference I have seen is when drilling SS with high speed steel or cobalt bits. The glue doesn't let the bit overheat and the SS doesn't turn blue like it often does. Use the glue and moderate to slightly high constant pressure and it drills right through. Again, I don't know the science behind why it works, but it does.
Old 05-06-2022, 03:37 PM
shermanator2 shermanator2 is offline
Stock Pontiac dowels are about 0.3096" diameter. With the Milodon splayed caps that I have, a 0.3096 dowel will drop into the holes, but a 0.3125 is not even close to fitting.
And BTW, I have bought dowels from http://www.precisionautomotivespecialists.com/. That is the only place I have found proper 0.3096" dowels. I also like the extra length of his.
The Following User Says Thank You to shermanator2 For This Useful Post:
Old 05-06-2022, 04:04 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Yes the 400 block I had converted the shop id not really check fit. One of the billet caps drops on the other 2 are tight as the spacing must be a hair off.
Skip Fix
Old 05-10-2022, 04:31 PM
Current Progress, I think the fixture is coming along nice. Now I need to pick up locations of dowels in the block and in the cap to figure out what amount to move holes to get back in line with each other. I am going to try to make 8mm dowels work.
ID:	590559   Click image for larger version
ID:	590560   Click image for larger version
ID:	590561   Click image for larger version
ID:	590562   Click image for larger version
Old 05-10-2022, 04:33 PM
I made the plates able to hold the block square and at 18°.
ID:	590564   Click image for larger version
The Following User Says Thank You to spectramitch For This Useful Post:
Old 05-11-2022, 07:01 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
Looking good! Alot of work for a 1 off project but moving rather well. Is that couple of injection molds i see laying around?
Old 05-11-2022, 12:18 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Nice work!
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 05-11-2022, 08:54 PM
Thank you, yeah its a bit of work but I am sure any engine machine shops near me would have totally hacked this thing up. Good eye those are some molds back there. Its crazy how many guys I work with making these custom molds and none of them have any idea what they are looking at when they see an engine block. One guy asked me “what are you doing for the exhaust there?” I said “what exhaust?”, as he pointed at the 3 freeze plug holes lol
Old 05-11-2022, 09:11 PM
Tom Vaught's Avatar
Boost Engineer
A lot of different knowledge levels out there. Congrats on a very nicely engineered fixture to drill your block.
Are you using bushings in the outer main caps holes to help locate the center lines of the drills when doing the initial small bit drillings
in the block?
Tom V.
Old 05-11-2022, 09:38 PM
in the block?
Tom V.
I did make a drill guide ‘sleeve’ to fit inside the splayed hole and have the ID be the tap drill for 7/16-14. I was going to use that for if I had to use my bridgeport with the head tipped. Now that im doing it in the cnc. Im not sure if I am going to use it or not because I am planning on installing the caps on dowels with block set on the 18* fixture side. Then tramming center zero in cap and spot facing, center drill, tap drill then tap.
Old 05-12-2022, 09:51 AM
Tom Vaught's Avatar
Boost Engineer
Thanks.
Tom V.
Old 05-19-2022, 09:29 AM
I have the new dowels installed and they fit very nice now. I have layed out the thrust 'step' dimensions. I will do a rough cut and re-install and make sure measurements are lining up before finish cut.
For drilling the 18° holes, how deep until the water jacket becomes close?
ID:	591134   Click image for larger version
ID:	591135   Click image for larger version
Old 05-19-2022, 10:15 AM
Tom Vaught's Avatar
Boost Engineer
http://forums.maxperformanceinc.com/...22#post2332622
All the info you need is here.
Thanks to Pontiac Jack and others.
"You don't really want .001" interference fit in the block. A "light press fit" is called for, which means very close to a "zero" fit. Usually the first 1/4" or so of a reamer is slightly undersize (some fraction of .001") and gives the fit you want.
You also don't want a 34mm long dowel- more like 5/8"-3/4", with more than half of it into the block. You could shorten them with a cut-off wheel, then grind a little chamfer on the cut end." Pontiac Jack
Tom V.
Old 05-20-2022, 11:21 AM
Out of curiosity, do you race guys use dip sticks? Or do you just assume no significant oil is lost between oil changes or tear downs? The reason this matters here, is that I have not figured out a dip stick solution that works with splayed caps. The stock dip stick would route through the splayed bolt. Something through the side of the pan could work.
  #38
Old 05-20-2022, 12:26 PM
AG's Avatar
AG AG is offline
I don't use a dipstick on my race motor and it does not leak oil at all. I change the oil frequently enough it's not an issue.
  #39
Old 05-20-2022, 03:26 PM
Dragncar Dragncar is offline
The only way as far as I know is to install one on the side of the pan. Canton makes a weld in version for their pans. You could adapt it to any pan if you wanted to bad enough.
I has Steffs weld in a bung for this on my aluminum pan I bought from them.
Not sure if I will even use it as there are plenty of knowledgeable racers getting by without any dipstick at all.
https://butlerperformance.com/i-2445...tegory:1285261
  #40
Old 05-20-2022, 08:27 PM
73 TRANSAM 73 TRANSAM is offline
What I did on mine is to weld 6AN fitting then use a braided line then cut it to length for the dipstick to read correctly. This way its flexible enough then when ur done, just cap it with a 6AN plug. Incase ur running a vacuum pump.
