Old 05-08-2022, 06:05 PM
alanmay0 alanmay0 is offline
could these be considered the type of bubbles in the radiator that would indicate a bad gasket?? I have a short video but guess cant upload video on this site.
ID:	590401   Click image for larger version
Old 05-08-2022, 12:08 PM
george kujanski's Avatar
8 bolt or 11 bolt water pump?
A 8 bolt pump (standard on a '67 I believe), has 2 extra pieces, a housing plate and a divider plate. The clearance should be minimal from the vane edges to this housing plate. it forms the rear cover of the pump housing. The divider fits midway between the pump casting and the the housing plate; it's purpose is to "divide" the flow from the pump to each bank. I don't know if there are tubes or if there is a rubber seal.
If it's a 11 bolt, there is no "divider" plate; the outlet of the plate is forming to contact the outlet tubes on each bank and the face of the tubes has the rubber seal. The clearance from the vane edges to THIS plate should be minimized as you say.
George
Old 05-08-2022, 12:23 PM
My water pump has the two dividers and I did my best to lesson the gap between the divider and the pump itself.
Old 05-08-2022, 04:17 PM
I cant find the post of the person who asked me to run the car to about 220 degrees and then read the temp of the center exhaust head. i did that and I placed the red temp dot on the 7 of the 670 on the head. the drivers side was 295 degrees and the pass side was 242 degrees.
Old 05-08-2022, 12:59 PM
Cliff R's Avatar
Cliff R Cliff R is offline
What pistons were used during the "rebuild"?
What camshaft?
Was the camshaft degree'd or just installed dot to dot?..
Old 05-08-2022, 01:02 PM
The cam shaft is basically stock, maybe just a little bit above but not noticeable. As far as the pistons go they did not replace the pistons this time because it has just recently been rebuilt, unknown to me, so they just honed out the cylinders and replaced the rings. I will check with the rebuilder tomorrow for more specific information
Old 05-08-2022, 01:05 PM
25stevem's Avatar
25stevem 25stevem is offline
Here is what should be present in the 67 water pump set up.
It would be a good thing to know how much cranking compression the motor is making.
Yes, cut the oil filter open.
I do stuff for reasons.
Old 05-08-2022, 01:20 PM
OK this picture does not show the use of the two rubber spacers/O rings or what ever. see attached picture
Old 05-08-2022, 01:29 PM
Murf Murf is offline
Is that a pic of your car? If not it doesn’t real pertain to anything here.
ETA you would be looking for metallic particles in the filter. Indicating some sort of engine issue.
Does it puke coolant when you pull over with the gauge pegged?
The more info you can give the better the advice will be.
Good luck!
Murg
Old 05-08-2022, 02:33 PM
No that is not my car that is a car on youtube that a guy is showing what can can cause the pontiac to overheat. I was just asking is those black rubber things are needed in the water pump. I have never used them, or knew they existed, until seeing that youtube video. The car does not puke water when I stop. I do take the temp reading with the laser gun and it is 245 plus degrees. I have not yet cut the oil filter open but was getting ready to but decided to get the temp reading of the center exhaust manifold when it hits 220 degrees as another on this site wanted to know. Well I started the engine and was letting it warm up. The temp at the thermostat housing was reading about 135 degrees so I was going to take the radiator cap off to see when the stat opened and if the water was flowing. well when I gently began lifting the radiator cap when the engine was only showing 135 degrees it nearly blew off with force in the radiator. So lots of anti freeze came bursting out but I was lucky enough to get the cap on before it all came out. Cant understand why the radiator would be filled with pressure or hot anti freeze when the thermostat had not yet opened. Any one have any ideals??
thanks again
Old 05-08-2022, 02:50 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
What pulleys system are you running? Hopefully it's not one of those slow water 6" crank pulley, coupled that with a 8" water pump pulley.
Old 05-08-2022, 04:26 PM
will cut oil filter open tomorrow. no it does not puke water
Old 05-09-2022, 05:50 PM
John V. John V. is offline
You mentioned you are running 60:40 coolant to water mix?
That will raise the boiling point but generally, I believe water may provide a bit better heat transfer. And if you haven't tested the mix, maybe you are running an even higher concentration?
I suspect a mechanical issue but just suggesting something else to consider. I realize you are in Texas and perhaps 60:40 is common there because of high ambient temps. Worth checking perhaps.
Next, you mentioned the intake crossover was blocked which is a common practice especially since our old Pontiacs mostly aren't driven in winter cold.
But a '67 would have used a RH exhaust manifold Heat Riser Valve. Just curious if yours was eliminated. With a blocked crossover, a stuck closed HRV would be a big issue but I'm thinking a stuck partially closed HRV couldn't be good for engine performance generally and probably cause high temps.
Hopefully yours has been removed or permanently opened.
You confirmed that you have the 8 bolt style Flowkooler water pump and you used the early style two divider plate package. As others have stated, the rubber seals were not used with the 8 bolt and assume the Flowkooler wouldn't need them either.
I think lots of folks have used a Flowkooler pump so I assume no issues there. For stock engines and radiators I have always been a proponent of stock pumps as they were designed for a specific flow rate to give the coolant residence time through the radiator. Pumping through the radiator too fast would not allow time for the best heat transfer.
When my engine was rebuilt, we used lifters I had purchased in the early '90s. One of them never pumped up. On disassembly it was discovered the lifter had come apart. IIRC, I was told lifters from that era had issues. The fresh engine had only been run for some minutes but we decided to replace the cam along with the lifters rather than worry about a wiped lobe. But seems to me you would know if you had a lifter/cam issue at start up well before it got hot.
Some years ago, I remember a guy was overheating. His upper rad hose was too long and trapped air (think an upside down drain trap effect). IIRC, he shortened the hose so that it wasn't arched above the inlet. That seemed to cure his overheating as the air was no longer trapped. Since you aren't boiling coolant, I would be suspicious of a temp misread because of air in the system but based on what you've done, aside from the hose configuration, I doubt air is your problem and the coolant really is getting that hot.
Since you saw a 53 deg F difference in center exhaust port temp from RH to LH head, I'm with 25stevem about the head gasket on the LH side and also Joe's Garage who judged the no. 5 plug looking a bit too clean vs. 1, 3 , and 7.
Your engine builder should be able to test for a head gasket leak. Since he re-ringed the pistons, did he install new head gaskets?
Old 05-09-2022, 06:52 PM
68WarDog's Avatar
What's the overbore with your 670 heads? Have you noticed any sounds of detonation ? Would you be able to run some 110 octane fuel?
Old 05-09-2022, 06:59 PM
The cylinders were bored 30 over on a previous engine rebuild. This rebuild cylinders only honed. No detonation at all. Don't know if I could run 110 fuel because in Texas you can't get it. Remember before the recent rebuild, 150 miles ago, I drove this car from Florida to Texas with no problems. although the temp sending was not working I detected no overheating problems at all. So something changed with the rebuild, I used the same water pump because it was a good one and worked fine. Very very confusing. I can not think of any thing else to try. So any help appreciated.
Old 05-09-2022, 06:53 PM
Thanks for all of your information. Yes new head gaskets were installed. Again today I rented the tester for telling if exhaust gases were in the radiator. I checked and double checked with this tester and could not get the blue solution to turn yellow. I did test the solution buy holding it by the exhaust pipe and it did turn yellow. Yes the heat riser is frozen in the open position. Today after adjusting the carb. the 53 degree difference between exhaust sides seems to have corrected itself and they both pretty much read the same. So today i also checked the compression and all cylinders were between 145 and 150. So you know I have an aluminum radiator and two 12" fans from Butler Performance who stated that this combination would cool any car on the road today. Not Mine. When the thermostat opens you can see the water flowing and the heater blows very very hot air. So the pump is working. Is it working too good maybe. I can tell you that the temp, when taken with the laser temp gauges, at the thermostat housing and again taken at the water pump intake where the lower radiator hose connects to the water pump are basically the same. The guy at Butler told me that a radiator can take about 30 degrees out of the water temp from top to bottom. This is not happening with my engine. The temps are about the same. Meaning that not much heat loss through the radiator. Both 12" fans are on but not pulling enough heat, or pulling all they can. Like i mentioned in my earlier post I have tried a different radiator and i have tried using the 7 blade clutch fan with no changes what so ever. So any suggestions you may have would be appreciated. I was thinking of tomorrow removing the plates under the intake manifold so that the exhaust could flow through the intake, dont know if that would make a difference. I am aware of what you are talking about with the large top radiator hose. I have seen those. Don't think mine is that long. I have been told that I might have a air pocket but I have changed the radiators and anti freeze so many times and flushed the system that I find it hard to believe that an air pocket is possible. I could be wrong. Any help appreciated. Thanks
Old 05-11-2022, 11:50 AM
Gary D's Avatar
Gary D Gary D is offline
Hi, First thing I would check is combustion gases/heat getting into your coolant system. I fought a heating problem for a long time and it turned out o be a bad block that had been repaired with a sleeve and I believe that hid the real problem. I bought a rebuilt 455 and had to rebuild it again. A bad Craigslist experience!! Long story short after trying every cooling combo available I finally checked for combustion escaping into my coolant and solved the problem. Destroyed that block as not repairable, transferred all my parts, problem solved. Just a thought!
Old 05-11-2022, 12:42 PM
78w72 78w72 is offline
Did the test for exhaust gasses in the radiator, could not turn blue stuff yellow.
FYI: he has checked that
Old 05-08-2022, 01:23 PM
so when i cut open the oil filter what exactly am I looking for. The engine has about 150 miles on it since rebuild. Thanks
Old 05-08-2022, 04:14 PM
that is exactly what i have.
