Old 01-02-2023, 09:23 AM
grivera's Avatar
grivera grivera is offline
Does installing a restrictor negatively affect system efficiency by slowing the coolant flow at head?
Will Rivera
Old 01-04-2023, 08:58 PM
Tom Vaught's Avatar
Boost Engineer
Not at all in a stock configuration.
If anything the coolant flow (from the front of the engine block then up thru the head gaskets, and then forward to the water cross-over, IS MORE EVEN WITH LESS FLOW BEING ROBBED BY THE HEATER CORE AND NOT COOLING BOTH HEADS THE SAME).
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post:
