Dataway, get a young lad (son, grandson, neighbors kid, lol) with small hands and see if he can reach it. Just a thought.
Cholesterol Bad Adrenaline Good Do it till your eyes bug out! |
| The Following User Says Thank You to Sport69 For This Useful Post: | ||
thank you
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
Do they work with the dimmer?
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman |
Amcmike, they seem to dim down to about 50% of their total brightness. That's not a problem for me, I don't run with them off after dark.
You have to get dimmable LED's and then yes, they will. Non dimmable ones (it only takes one) will fry the fuse the moment you twist the dial.
Long live the Muscle Car Instagram @tuske427 1967 Firebird #BVbird 1967 Firebird 400 4 speed project 1969 Verdoro green GTO (daily) |
Hey, spent most of the day putting in my new (used/ OEM/uncut) dash bezel, and I wanted to correct a previous post, the LED's I put in it do dim completely, not 50% as I previously posted. Once I got the dash in I gave them a test run, I would say they worked great since I was able to see them in the daylight.
Mine are not dimmable and work just fine after twisting the dimmer. All they do is just go out when the dimmer is turned all the way down and come back on when you turn it up.
I'm World's Best Hyperbolist !! |
Dataway, I'm just glad I'll finally be able to see them after dark. I absolutely hated having to remove that bezel again, what a chore! I wish there was an easier way to installthe headlight switch, that's the worse part.
Mine have the same behavior. No issues with blowing fuses, if I try to dim them, they just turn off. They come right back on if you twist the dimmer back up to full brightness.
| The Following User Says Thank You to JLMounce For This Useful Post: | ||
I wasn't so lucky. Mine would pop fuses the moment I twisted the dial (not my Firebird, but another car I put some LED's in)
Tuske, that sucks! I hate electrical issues! When I first putt mine together my brake lights wouldn't work, it took three days of troubleshooting to find a courtesy light bulb in the passenger side had the contact wire cockeyed and was grounding it out. All I had to do was remove the bulb, allow the spring loaded wire to reseat itself, and reinsert the bulb, #**#*@! Everything worked after that.
