Old 07-21-2022, 10:21 PM
Scott Roberts Scott Roberts is offline
It needs higher compression.. not good on a 9.5-1 motor.. install It straight up.. has a good bottom end grunt for a heavier car... jmo.
Old 07-21-2022, 10:23 PM
Originally Posted by Johnny406 View Post
Not intending to hijack but what is the minimum/maximum compression range of the 290b6?
11-1 or better in my opinion..
The Following User Says Thank You to Scott Roberts For This Useful Post:
Old 07-22-2022, 06:14 AM
25stevem's Avatar
25stevem 25stevem is offline
In a 455 it seems that 11.5 is a good starting number for strip usage in something 400 cid or less 12.5 should be the minimum target.
I do stuff for reasons.
Old 07-22-2022, 01:15 PM
Half-Inch Stud's Avatar
Lower signature info was street/strip use, and breached the headgasket between cYLs 2-4 after 4-years street duty. Probably low octane ping on a hot day on the highway.
Old 07-25-2022, 09:32 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Originally Posted by 461-69bird View Post
Jack, mine is a 472 stroker, does that make a difference?
It may but I don't know what it would be. IMO a 106 LSA is pretty tight for larger cid. I went with a 110 on my 482.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 07-25-2022, 05:05 PM
461-69bird's Avatar
461-69bird 461-69bird is offline
What car was that in Jack and was it street,strip or both?
69 Firebird
472, Bullet SFT, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 11.14@120
Old 07-25-2022, 07:54 PM
One is a 64 Tempest the other a 72 LeMans. The 72 is a drag only car and the 64 saw both track and street time. Both engines built identical.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
