How are your eyes?
I had no use for digital readouts until I hit 55 or so. Now they're a real blessing. Fookin' bifocals. I hadda buy a new 0--1 with liquid-crystal display just so I didn't need a magnifying glass. |
| The Following 2 Users Say Thank You to Schurkey For This Useful Post: | ||
I can still read the barrel vernier scales( with glasses) but the DROs make it so much easier. When I worked for JET most of our constant use mics were DROs.
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
Well, that happened fast. Nabbed a set of used Mitutoyo mics off eBay . As far as I can tell they have ratchet thimbles which I think I would prefer. A little over $200 for the set of 4 ranging from 0" to 4". Considering a new set of 4 is almost $500 I'm feeling alright about it.
My eyes are still holding up ok, but I'm probably due for a pair of readers soon.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
| The Following User Says Thank You to Verdoro 68 For This Useful Post: | ||
I have a ring breaker I bought from Sear in the 70s and never used until recently to take some rings OFF some pistons I bought used. I always worried about stretching them too much installing with it.
My probably Chinese mikes were good enough I could tell my Eagle 409 stroker crank had terrible journal taper! They do read right on the standards they came with. But I have the machine shop double check me when they are doing the final machining.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed Last edited by Skip Fix; 07-22-2022 at 03:24 PM. |
I moved on to shopping for dial bore indicators. Most of the inexpensive ones geared toward engine building are .0005. I’m assuming I’d want .0001 for more accuracy and one that could do cam, main and rod bearings? I’ve also been reading about how the cheaper gauges can mar bearings. Is that a concern?
Of course, all this is making me wonder if I should have just started with plastigauge but I enjoy learning about these tools and how to use them. Wish I could take a few of mgarblik’s classes.
Maybe we can get him to post the syllabus, and the textbook name and ISBN. Who knows? Is the course available online, or via Zoom or some-such? |
Not to hijack thread: I will start a new thread in about a month for anyone interested. It will highlight what our 1 year long course is about. I will post syllabus and some worksheets and class notes. I have never done anything like this on a forum, so have some patience. Thanks for the interest. Students over 55 years old who live in a multi-county area around Dayton Ohio can take the classes virtually for free with some lab fees. Class fills very fast. One of the areas best kept secrets. Sinclair College is a local tax supported state school. Next class starts August 23rd. It is filled with 5 on the waiting list.
| The Following 4 Users Say Thank You to mgarblik For This Useful Post: | ||
numbers are all cool and stuff but there is also the "feel" to using a pr of mics and setting a dial bore gauge. Working within .0005 should be your goal WITH SOME PRACTICE. The average seasoned machinist is doubtful at +/-.0001 just due to the 100000 variable involved with measuring. Do you realize that the oil left behind from your fingerprint is typically .0001" thick?.... a sharpie marker is about .0003". I can put the BEST steel wrist pin in my hand in a 72* environmentally controlled shop and within 2 minutes make it .00015 BIGGER than when it is at 72 degrees. Your dealing with steel and aluminum, both are about as stable as a wet 2x4 in the sun. Don't get lost in the numbers....just understand what your numbers represent.
| The Following User Says Thank You to 67Fbird For This Useful Post: | ||
" Long may we DRIVE !" |
After I gained that perspective, I went ahead an ordered a .0005 bore dial gage. Bonus - the set I got off eBay was previously owned by another Ken, or Kenny in this case, so my name came pre-engraved ![]()
Those MIC's look nice. The hardest part of getting that 4th digit is hitting the sweet spot on a cylindrical object. Pistons are the toughest because they are not round. So there is just one spot on the skirt that is the maximum diameter. I would start with lifters, easiest to measure, then valves and pushrods, then crank journals. Pistons and camshaft lobes are a challenge. Good luck.
| The Following User Says Thank You to mgarblik For This Useful Post: | ||
My rotating assembly from Butler finally shipped and I think I'm ready for it.
Here's where I netted out on my tool cache for the build:
I watched a bunch of torque wrench tests and reviews on YouTube and was surprised to see the HF Quinn hold it's own with the bigger names. Seemed like a good value, especially with $40 off as part of their parking lot sale. Grabbed it for $139. Did some homework on bore dials and couldn't justify the expense of the bigger names so I went with the Fowler from Amazon. From trials on the old rods and bearings, dial bores definitely take some practice, but this one seems to do just fine.
Everything you have in the pic should get the job done for you. The only thing I see you might not be able to measure is the #3 housing bore and bearing clearance. Just not sure. It looks in the pic like the dial bore gauge might be a little too short to get to #3. I think you can get to 1,2 from the front and 5,4 from the rear. Possibly #3. Not a big deal either way. Enjoy your build.
| The Following 2 Users Say Thank You to mgarblik For This Useful Post: | ||
