Old 08-22-2022, 09:39 AM
Tom Vaught's Avatar
Boost Engineer
Some of the Black Floats were not sealed up very well by Holley or Modifiers.
Tom V.
Old 08-22-2022, 09:44 AM
Tom Vaught's Avatar
Boost Engineer
Very Few understand Transfer Slot position and the effects it has on the ability of the carb to perform properly.
That is why you get the Primary Side "Blade Position Window" vs the Transfer Slot perfect and add extra idle air if needed with secondary blade opening or Idle By-pass Air circuits.
Tom V.
Old 08-22-2022, 10:57 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
Tom V.
Actually I believe these started off white, turned yellow. You could see the gas inside the float when held up to a light.
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
Old 08-22-2022, 11:31 AM
fastekibeast fastekibeast is offline
Ok, you guys told me alot good and relevant info, I really appreciate it.
I try to keep those hints in mind.
Janne
Old 08-22-2022, 08:30 PM
Tom Vaught's Avatar
Boost Engineer
Two different Floats. One white Plastic that turns to yellow and the Black float which is phoenelic.
Picture of white float in this link.
https://ballofspray.com/forum#/discu...oat-level-help
Tom V.
Name:	black float hly-116-10_xl.jpg
ID:	597017   Click image for larger version
Name:	black float hly-216-9_xl.jpg
Old 08-24-2022, 01:07 PM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
That's interesting, regarding using a PV that is 2 or 3 inches less than car idling or in gear. I always thought one divides in half was bang on as holley's videos mention that. I certainly went down the path of larger squirters and 50 cc pump arm to overcome lean stumble.
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
Old 08-24-2022, 06:23 PM
Tom Vaught's Avatar
Boost Engineer
Actually the rule of thumb was vacuum divided by 2 and then ADD one number to the previous calculation answer. Or for example: engine idles at 11" of vacuum.
11" divided by 2 = 5.5 then add one inch of vacuum so the correct number to be installed would be 5.5 plus 1 = a 6.5 Power Valve.
A larger value number will ADD extra fuel SOONER.
Tom V.
