I remember back in 60s buying used Lakewood Pontiac bellhousing for $50.00! No bs.
That sounds about right. The Lakewood I bought from this forum last year I think I paid $300.00 for plus shipping. It was in great shape and had the block plate as well. I have had great luck buying things from this board and try to offer killer deals on the stuff I sell as well here. I try to feed the hobby.
A heavy as the things are, as long as they are not butchered and have the Block-Saver
plate they are basically as good as new, they never wear out. I have a much older Lakewood scatter-shield, (before the shields even had the front plate) that I use on a "Engine Run Stand". Purely to do actual engine run time making sure the carb is spot-on at the idle and part throttle/ transitions areas on the carbs. It has paid for its self many times over the years. The Lakewood bolts right on to the rear mount in Picture#2. The side arms swing over and pick up the Side Engine Mounts. So the older Lakewood products can do a lot of other Pontiac engine work without being installed in a vehicle. The $800 savings vs the Quicktime shield paid for 1/2 of my run stand basically. Tom V.
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 08-25-2022 at 10:15 AM. |
My old machinist n his old dial dyno required a scattershield.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
pretty sure mine is a mcleod. big heavy bugger.
I have a 40+ year-old Lakewood can on my '61 Corvette. When I rebuilt the trans and engine 3 years ago, I learned something from Paul at 5speeds.com: when using a block saver plate with a scattershield, it is a good idea to change out to an extended pilot bushing. The block saver plate moves the trans away from the engine about 3/16". pulling the pilot shaft of the trans out of the bushing or bearing that amount. The extended bushing supports the entire input/pilot shaft, not just the tip of it. I installed a brass extended bushing in my car during its assembly.
The reason the transmission needed overhaul was that the Lakewood shield had been installed with about .120" runout, resulting in a destroyed input shaft.
Jeff |
Good Advice, I also have extended the bushing the thickness of the Block Saver Plate a couple of times for different Pontiac engines.
I used a Chevy Application bushing, measured the crankshaft hole carefully, and had the bushing trimmed in outside diameter for a snug but not tight fit into the crankshaft. The Chevy app has a larger OD for the bushing. I had a bearing fail one time and it basically wounded the input shaft bad enough that it needed to be replaced on my Original 4 speed muncie trans. No more input shaft bearings at that location for me. Tom V.
| The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
