There's a guy named Hector Carrillo that advertises on the Pontiac FB groups (search Carhex) that rebuilds steering boxes. They look pretty nice and he will do a exchange or rebuild your own box with fast ratio gears. From what I've read people seem pretty happy with him and he's reasonably priced. He's out of California.
The Following User Says Thank You to RocktimusPryme For This Useful Post: | ||
This is the best concerning non-rack boxes. They are not in stock but may know of others who do:
https://turnonesteering.com/products...teering-boxes/ |
My vote is to keep the box original with the car. Quick ratio parts can be swapped in. You would be assured the stops will be the same. The only other thing to think about is the torsion bar. You might want to consider if you want it increased or not. It has to do with the effort needed to turn the wheel.
The Following User Says Thank You to rohrt For This Useful Post: | ||
"The only other thing to think about is the torsion bar. You might want to consider if you want it increased or not. It has to do with the effort needed to turn the wheel."
X2 .
I had my GTO steering box built here: https://leepowersteering.com/
They did a nice job about 8 years ago, been ok since then. The owner told me he used to work for Mickey Thompson. |
1. The FIRST thing you look at is the rag joint. Rag joint issues are absolutely epidemic on GMT400 pickups and SUVs ('88--98-ish pickups, and their related SUV cousins) Rag joints have a certain lifespan, and A-body originals are way past that at this point. The "rag" gets sloppy from wear, age, and general deterioration. Then all the motion is transmitted by the "safety stops", leaving a dead area in between where the rag just flexes without turning anything. You can see evidence of this by closely examining the safety stops--if they're polished, they're in contact, and if they're in contact the rag is shot.
2. All the other suspension/steering joints and rubber bushings are similarly suspect, as is the wheel-bearing adjustment and the alignment angles. Be sure the frame isn't rusted/cracked/broken in the steering box area. 3. There's multiple parts in the steering box that affect how it "feels" as you drive. The gear ratio; including whether it's a fixed- or variable-ratio. The torsion bar, (stiffer has less assist, more road-feel) and the steering stops. And of course, BOTH adjustments. The common problem is that the second adjustment is too tight, because the first adjustment is too loose, and they're trying to compensate. ALL of this needs to be "right". If any one of these variables is "off", you'll be unsatisfied. For example, someone who shall not be named but who's initials are "ME" installed a '75 Nova steering box into a '68 A-body, because he figured that at 2.5 turns lock-to-lock, it had to be a fast-ratio gearbox. No, not so. It's a slow-ratio gear box, with restricted travel via internal steering stops. A-bodies don't use steering stops in the gearbox, the steering stops are when the steering knuckle hits the reinforced pad on the control arm. So now, his A-body takes forty acres to make a U-turn, and still has a crappy ratio and torsion bar. For the record, the "Hot Trick" for '64--'72 GM A-bodies is to grab a used-but-usable steering gearbox from a '92--'98 Jeep Grand Cherokee, and a 7826542 rag joint plus 7807271 pinch-bolt or aftermarket equivalents. That box bolts to the A-body frame and Pitman arm, the new rag joint adapts the input of the box to the steering shaft on the vehicle. The box has the fast ratio, the second-stiffest torsion bar, and pitman-shaft travel angle suitable for an A-body. They practically gave 'em away at the Treasure Yard. The single fly in that ointment is that you need to adapt your PS hoses to the newer, metric (16x1.5 and 18x1.5) /O-ring machining of the Jeep gear box. Easily done via a variety of methods. Including fluid, hose adaption, and the rag joint, you could have the Jeep box installed and working in your A-body for under $200, maybe under $100. Adding the higher-pressure relief valve from a '70 or later power steering pump is probably a good idea, for '69 and earlier vehicles. https://www.chevelles.com/threads/fa...grade.1131928/ Last edited by Schurkey; 10-25-2022 at 04:56 PM. |
The Following User Says Thank You to Schurkey For This Useful Post: | ||
I mean the 2.8 turns lock-to-lock box.
@Schurkey, " 40 acres to make a U-turn.". OMG LOL, gotta pee |
As I found out, "turns lock-to-lock" means NOTHING unless you're also comparing it to the pitman arm angular travel. The 64--72 A-body needs nearly 45 degrees of Pitman arm swing. Many, if not most other gearboxes are limited to ~35 degrees of swing. So, sure, they have great "lock to lock" numbers, but the vehicle doesn't turn very sharply. Thus the "40 acres". One steering stop is the end cover of the box. Easily changed. The other steering stop is deep inside, the whole box has to be gutted to get the right one in place. Oh, yeah. One more thing. If you think you're gonna be clever, and just get a parts-store rebuilt box for a Jeep Grand Cherokee, and you think you'll get all the good parts in a freshly-built box with a warranty...think again. The companies that rebuild steering boxes DO NOT guarantee that the internal parts will be "correct" for the application. You may--or may not--get the fast ratio, the second-stiffest torsion bar. You might end up with some random fast ratio, or whatever torsion bar is closest to the guy doing the work at the time. Thus my preference for getting a "good used" box directly from the Treasure Yard, rather than buying a rebuilt Jeep box from the local parts house, or Amazon, or eBay, or whatever. Last edited by Schurkey; 10-25-2022 at 05:10 PM. |
I can’t believe no one mentioned Borgeson. Cheaper than a lot of these rebuilds, brand new, 3 year warranty and modern guts for a more modern drive feel.
The Following User Says Thank You to 64speed For This Useful Post: | ||
Sorry if it has already been mentioned but the steering shaft has a U-joint in it that wears out I had to replace mine it had a lot of slop
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ([_|_] ##\|/##[_|_]) |
"Steering box includes adapters to be able to use either O-ring or flare style hose connections." What did you do for your 64's PS pump? Thanks.
"No replacement for displacement!" GTOAA--https://www.gtoaa.org/ |
Just a stock Saginaw pump
I did the Jeep Grand Cherokee box conversion when it was a thing. Bought a remanufactured box from Autozone and am very happy with the feel and the ratio. Not twitchy (good ratio) and feel. It makes my '71 GTO feel very similar to the 3rd Gen Z28 my son had. No leaks on mine, but I can't speak for today's cores.
The $1,200-$2,000 they get for specialty boxes seems crazy to me for an occasional use car but to each his own.
Triple Black 1971 GTO |
#38
I was happy in 1979 because at the time my other car was not an Audi Q8, plus beer sort of made everything sloppy. All kidding aside we never drove at the speeds on a regular basis that people drive at today. When I have the Goat on the highway cruising at 70 I am getting passed by scores of little cars being driven by nurses to youngsters who are texting at the same time. Just would like the feel to be a lot tighter at speed if I can.
1971 GTO Convertible 455 #64 Heads, HO intake and carb with MSD HEI, RAIII exhaust manifolds and 3:55 posi |
#39
I recently put a Borgeson sourced from Ames in my car. You can use a stock pump and hoses but will need to use the small rings they supply that go into the box at the hose threads. Mine works fine, no leaks. Only complaint is it spits fluid out of the vented cap hole and perimeter of the cap. I need to try a different cap to hopefully solve this problem.
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
#40
[QUOTE=OCMDGTO;6382444]I recently put a Borgeson sourced from Ames in my car. You can use a stock pump and hoses but will need to use the small rings they supply that go into the box at the hose threads. Mine works fine, no leaks. Only complaint is it spits fluid out of the vented cap hole and perimeter of the cap. I need to try a different cap to hopefully solve this problem.[/QUO
