Old 01-19-2023, 10:27 PM
graygator graygator is offline
When I converted a 64 chevy 1 ton (all drum) from a single pot to a dual master cylinder, I added 10 psi residual pressure valve (RPV) from Wilwood to each circuit (the new master had to built in RPVs). 10 psi RPVs keep the springs from pulling the shoes too far back. I think you need them but I don't see how the lack of them would cause the brakes to be grabby.
Also when you say the fronts grab, is it both fronts or does it pull to one side?
Kent R.
The Following User Says Thank You to graygator For This Useful Post:
Old 01-20-2023, 11:04 PM
Hotrodjohn71 Hotrodjohn71 is offline
First. Thank you to all of you. I am carefully going over your advice
I've been driving the car around today. I've got a pedal that goes down about half way then the brakes come on quick and strong. Not grabbing after changing the rear shoes.
I would like to be able to fix that pedal drop and it will be great.
I can say with certainty that my master cylinder is a 1" bore. I measured the new one and the old one and both 1". All of the research I've done shows that the 4 wheel drum cars had a 1" bore, and also., that's what aftermarket lists.
Regarding the booster to Mc pushrod, I have just under 1/8" play measured by putting some body putty on the rod, assembling the setup., and measuring the crush height of the clay.
I have no fluid loss in the reservoirs, no tracable leaks, all adjusters are set up for a light drag on the wheels. All shoes are also new and of same brand.
I took a video of my Mc with the lid off :
https://youtube.com/shorts/5uTBwojVVnw?feature=share
and right when I press the pedal, there is a 'slight' geyser effect right when the pedal is pushed, and then no effect on release of pedal.
Are the 10lb residual pressure valves (either in-master, or wildwood inline inserts) designed to keep the inner cups in the wheel cylinders against the wheel cylinder push rods?
I'm wondering if that possible variable in 4 wheels could be causing the pedal drop.
There is no "spongy" when the pedal drops halfway, but I am certain the Mc is being engaged.
I found a Mc on ebay that looks in very good shape. I am hoping it will have the rpv's in good shape because I would like the original look.
Any thoughts?
ID:	605635   Click image for larger version
ID:	605636   Click image for larger version
ID:	605637   Click image for larger version
Old 01-21-2023, 12:00 AM
Sport69 Sport69 is offline
Make sure you have all the air bled from the lines (farthest to the closest bleeding order).
Double check your booster vacuum line and connections.
Power booster plunger rod is original to the car, and was originally inserted into the bottom hole on your brake pedal?
All brakes adjusted with a slight drag?
Zero leakage at the wheel cylinders?
Cholesterol Bad Adrenaline Good
Do it till your eyes bug out!
The Following User Says Thank You to Sport69 For This Useful Post:
Old 01-21-2023, 12:23 AM
dmorg1's Avatar
dmorg1 dmorg1 is offline
The 1" MC is correct for your application
I dont have a service manual handy right now but I believe that the MC/Pushrod clearance should be more like 1/64" .016". Tuffstuff aftermarket instructs no more than .020" clearance.
Adding the RPVs will certainly help keep the cups extended but will you be able to notice a change in pedal travel? Only one way to find out.
Dave
68 GTO
68 GTO Convertible
68 LeMans
68 LeMans Convertible
68 Tempest Convertible
79 Firebird
The Following User Says Thank You to dmorg1 For This Useful Post:
Old 01-22-2023, 12:52 AM
gto4evr gto4evr is offline
are there new wheel cylinders in there? I had a 67 with power drums that would pull to the right all the time under light braking, but was fine on a hard stop. no matter how I adjusted the brakes or how many times I bled the brakes, I couldn't get it to brake straight with a light pedal. I ended up just changing it over to power discs after screwing with it for a year since I'd planned on upgrading the stopping power anyways. a few years ago a PY member was looking for original wheel cylinders to rebuild so I pulled my stuff and took them apart to clean up the rust and caked brake dust. I found the left front wheel cylinder had some grime in the bore and the metal cups were hanging up, So a hard push on the pedal would get them to move, but they didn't want to move without the extra pressure. they weren't frozen, they just didn't like moving freely and weren't really dragging without the pedal. also not a drop of fluid leaking to indicate anything was up with it so i ignored them as a possible culprit.
Just a thought on something to check. you can pop the cylinders apart carefully and not damage them for reassembly just to check the bores in them.
The Following User Says Thank You to gto4evr For This Useful Post:
Old 01-22-2023, 12:51 PM
66sprint 66sprint is offline
Did you replace the 3 brake hoses?
I had a similar issue on an older car and found one of the front hoses had spilt the inner liner allowing fluid to pass into the outer part of the hose.
It never leaked but you had to push a bit on the pedal before it built up enough pressure to activate the cylinders making them suddenly grab.
If you haven’t put on new hoses, try feeling the old hoses for soft spots.
The Following User Says Thank You to 66sprint For This Useful Post:
Old 01-22-2023, 01:09 PM
Sirrotica's Avatar
I had a customers ford bronco that had very erratic braking, I also tried adjustments etc. I was talking to the local ford dealerships parts manager about it, when he suggested replacing the flex hoses. Seems ford had a bunch of problems with the inner brake hose delaminating and making a block off valve internally in the failed section of the hose, causing very erratic barking. New hoses got rid of the problem. The car was only a few years old at the time, so brake hoses weren't suspect due to age, but they were manufacturer defective.
I have also seen the metal swagged fittings rust internally and the swelling from the rust pinches the rubber hose causing a one way valve, where the brake spring pressure doesn't have enough force to return the fluid to the master cylinder, keeping the brakes applied partially. It causes premature wear of the brake linings, as well as excessive heat to be generated, similar to driving with your foot resting on the brake pedal while driving.
Neither scenario shows anything abnormal from looking at the brake hose externally.
Two instances I had forgotten about until I read the above post.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 04-24-2023, 02:12 PM
I wanted to come back to this thread to put a period at the end of the problem and thank everyone for their contributions.
I got my issue solved by finding a master cylinder that would accept the residual pressure valves.
I was blessed to find a master cylinder on eBay that was not only unused, but it had the stamping correct for our firebird and also it had the bleeder screws on the master cylinder itself which aided greatly in bleeding the master cylinder during the brake bleeding process.
That Master cylinder, although having provision for the residual pressure valves, did not actually have them. Finding a brake master cylinder rebuild kit for that 1-in bore with the two residual pressure valves, for the front drums and rear drums, was a challenge. But I was able to find one. All of that brought the pedal up to a good height.
Then after installing all of that I still had extremely sensitive brakes. Like one-toe braking which was awful for a panic stop.
I considered the advice that the 11 inch booster on our car was too much boost causing the grabby brakes ( even though, apparently for the power all drum brake 67 firebirds, the only option was an 11 inch booster) as was shared here in this thread. I obtained a nice Delco Moraine 9" unit and installed it and it's a world of difference.
So the residual pressure valves gave me a higher pedal and the smaller booster gave me a good pedal that wasn't extremely sensitive.
While going over all of this, I noticed that on the 62 to 67 Chevy Nova and Chevy 2, for the aftermarket power brake booster kits for their (all drum cars), those kits used a 9 inch booster.
Thank you for all of your help and advice in this problem, it is solved.
The Following 2 Users Say Thank You to Hotrodjohn71 For This Useful Post:
Old 04-24-2023, 04:38 PM
dmorg1's Avatar
Glad to hear that you were able work it out. Good information, thanks for posting up your results.
Dave
68 GTO
68 GTO Convertible
68 LeMans
79 Firebird
