If the deck is to tall to start with the heads should end up where they were supposed to be in the first place
If your not at the table you're on the menu A man who falls for everything stands for nothing. |
There are a bunch more reasons to deck a block other than just trying to get the piston near the deck height.
Surface finish is one depending on the head gasket planned, but the bigger reasons are to get the darn thing square in the first place. I've had brand spanking new blocks that weren't straight, and most all of your factory stuff will not have a straight deck surface. I've had them higher on one end than the other and even twisted from end to end several thou. This alone will determine how much needs to come off in the first place, then worry about piston to deck clearance and what you're willing to do there. Decking the block is just a normal part of the engine building process as far as I'm concerned if for nothing else just to make sure it's square. Even the last 455 I built that didn't have but a few thousand miles when it came to me from another builder, I went through again for a member here, and even though it had been decked, it was not square at all, and Paul took a fair amount off to correct that thing. What I haven't seen or experienced yet, is after a proper deck surface is established and that engine is run for years and 10's of thousands of miles and thousands of heat cycles, does the deck surface move? Is it going to need another correction? I haven't revisited that myself with my own personal engines. If it does, did you achieve zero deck by moving the piston pin height or did you shave the block a bunch? Is there enough left to clean it up? Maybe it's smart to leave the pistons .005" down for some wiggle room. Or maybe you just want to order custom pistons and move the pin height. ![]() |
The Following User Says Thank You to Formulajones For This Useful Post: | ||
Main bore diameter divided by two added to the distance from the edge of the bore to the deck......I hope I got that right it's pretty early in the morning and my coffee isn't done brewing yet!.....
The Following User Says Thank You to Cliff R For This Useful Post: | ||
We have a squaring fixture like most shops that corrects the deck to the cam/crankshaft centerline. Every block is different but speaking in generalities, Pontiac blocks are better than the average iron V-8 vintage block. I think the very worst Pontiac I have personally squared was .009" out of square. Typical is .003-.004. Worst blocks as a group are the old school SBC ones cast in Mexico! All I can say is WOW! Had one last year from a student that was .021" out of square. High on one end , low on the other, twisted to hell and back. I made him re-set it up in the mill 2 times before I really spent a bunch of time with him. Was sure he had something under the parallels or in the main pucks. Nope, just a terrible Chevy piece of junk. As expected, we had issues with the cam tunnel as well. It turned out OK after a bunch of work.
The Following User Says Thank You to mgarblik For This Useful Post: | ||
I've had cam tunnel issues with Pontiac and Chevrolet, Ford not so much.
Just seems like the decks are always out of square no matter what brand engine it is. Even brand new blocks. |
[QUOTE=track73;6413924]
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
We have seen more cam tunnel issues with 455 blocks.Tom
The Following User Says Thank You to tom s For This Useful Post: | ||
Don't think anyone has mentioned that the magic number for the main journal size is not the 3" or 3.25" since that diameter is the crank, and the bearing thickness and running clearance is also in that number. Someone please confirm my numbers but pretty sure the radius numbers I use are 1.595" for three inch mains and 1.720" for three and a quarter inch mains. Too cold to get out to the garage to dig out my notes.
While I do my measuring with a 12" caliper, I prefer the setup the machinist uses. I figure that if we agree then neither of us probably made a mistake. Corny, but measure twice, cut once applies to more than carpentry. I would agree that the 455 block cam tunnels are the worse, but most of the tunnels are always out a little bit and require just a very minor touchup with the cam bearing tool. Also agree most original Pontiac blocks are within .004" and the only disasters I've seen have been previously decked blocks and some of those remind me of ocean waves. I rebuilt a friend's original 1972 455 H.O. block that was previously rebuilt by a "race shop" in Los Angeles and I swear it looked like they decked it with a belt sander.
The Following User Says Thank You to lust4speed For This Useful Post: | ||
![]() Quote:
So with that almost always involves cutting the caps and align honing. Especially when the bolts are changed to something that torques differently. As far as dimensions, each machinist is probably different in what they like to see. I don't remember those specifics but that's why I pay Paul to do it ![]() Last edited by Formulajones; 03-13-2023 at 01:34 PM. |
![]() Quote:
Thanks for all the pertinent info, guys. I used to live in IA but am in IL now, between Joliet and Bloomington-Normal (yes, Pontiac, no joke).....I'm getting ready to start on an engine project for my latest Lamnas, which I'm picking up in a couple weeks.
I think I'll start a machine shop thread |
