OHC-6 TECH Over Head Cam projects, questions and advice.
Old 03-29-2023, 07:13 AM
That is interesting Jeff, So it looks like there are 2 A.I.R rear brackets. My car is a 4th week of June 67 car, so very late production 67.
Well believe it or not the engine and trans are out as of yesterday afternoon. The only hiccup was the plug for the rear sea of the Saginaw 4-speed popped out during the removal spilling the used 90w oil on the shop floor, stinking up the shop, and laughing at the oil dry now floating around on top of it! I could not drain the transmission as this Saginaw 4-speed does not have a drain plug hole drilled or tapped. UGH
Today I will drop off the battery tray, and A.I.R. brackets to the powder coater today.
I will verify what version of the Saginaw 4-speed I have, other work accomplished, I cleaned out the rear axle oil, & refilled, so after this project is done, the only fluid left to change will be the front brake fluid.
Name:	engine at angle.jpg
ID:	609895   Click image for larger version
ID:	609896   Click image for larger version
Old 03-29-2023, 07:50 PM
Hokie1984 Hokie1984 is offline
There has been some debate about the 7 bladed flex fans, but I believe what you have is stock for an AC car. My Sprint is also late 67 {April build) and has the same fan. Not sure if you know this but you can drain most of the oil from a Saginaw by pulling the bottom bolt holding the tail housing.
The Following User Says Thank You to Hokie1984 For This Useful Post:
Old 03-29-2023, 07:51 PM
I did not know that wish I did before this job! Thanks for the tip
Old 03-29-2023, 07:56 PM
LOL, I didn’t know about it until a few years ago after spilling a lot of oil over the years.
Old 04-02-2023, 12:00 PM
Cammer-6 Cammer-6 is online now
how many grooves in the input shaft? that tells ratio
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 04-03-2023, 12:20 PM
I will find out later this week, when I get back home, did not have time to pull it before going out of town for work.
Old 04-05-2023, 06:12 AM
Jeff Hamlin's Avatar
Thumbs up IDLE CONTROL SWITCH;
Good move getting the switch off and out of the way.
I have not seen any in a very long time.
Old 04-05-2023, 07:18 PM
Looks to be a 3.11 1st gear Saginaw 2 rings on the input shaft. Also found one of the upper tail housing bolts is missing, good thing I didn't scrap the 3-speed Saginaw I have had sitting under the work bench last fall. I think it will be donating a bolt to the Firebird!
The only reason I didn't scrap it last fall was I was to lazy to take the bell housing off of it! Some times it pays to be lazy. It is a column Shift transmission so I do not have any use for it. I scrapped 2 floor shift 3-speeds at the time.
Name:	Input shaft.jpg
ID:	610255   Click image for larger version
Name:	Missing Tail Housing bolt.jpg
Old 04-06-2023, 08:22 AM
You should pull the tail shaft off the 3 speeds before scrapping. At the very least you could sell that piece. It took me over a year to find one when I did my 4 speed conversion in my Sprint.
Old 04-06-2023, 01:09 PM
now I know where all those NOS A/C idle controls went..Between you and Fred.
I found a source of some made for Mopar,Port is in a different location from what I remember. I bought all they had.Odd but also have an NOS Y pipe with a MOPAR sticker on it.
Old 04-06-2023, 01:14 PM
save those 3 speed Saggys
share many parts with the 4 speed.
One car Im running a Vega trans
IIRC its a 3.50
Old 04-07-2023, 06:51 AM
GARY, How the hell are you man?
Long Long Time, hope all is well!
Old 04-07-2023, 12:35 PM
X2 Gary, glad to see you still here!
As for the Saginaw 3-speeds I scraped, I tried to give them away locally, no one wanted them, only a scrapper responded to my CL ad, and I decided to get the $$$ for them. I will take off the tail shaft housing and bellhousing off the last one I have, it came from a very rusty 66 Tempest 1bbl many years ago. Forgot I had it.
Jeff you ended up with the dust cover off of it!
Old 04-10-2024, 09:24 PM
Finally got a chance lately to get back to work on this, Cleaned and Gave the replacement engine a Flint rattle can overhaul. Cleaned the bell housing and A/C compressor brackets.
Today I Cleaned the Saginaw 4-speed, and found a couple things I found interesting. I never knew the was a difference between the Transmission rear mount, and the counter weight mount. Both of the originals are in good shape. and the the P/N's are visible. Also the rubber on the counter weight mount has "Blue" cast into the rubber. Strange that they have the same P/N but there are obvious differences.
First Picture is of the dirty Transmission with the aftermarket Hurst shifter
2nd pic shows the differences in the mounts
3rd pic is of the rear mount P/N 9788007
4th pic is the weight mount P/N 978807 Blue with Steel
The last picture is with a coat of Cast Iron paint applied.
Name:	Saginaw 4-speed dirty.jpg
ID:	631888   Click image for larger version
Name:	Trans Mount differences.jpg
ID:	631889   Click image for larger version
Name:	Trans Mount PN.jpg
ID:	631890   Click image for larger version
Name:	Trans Weight Mount PN.jpg
ID:	631891   Click image for larger version
Name:	Trans Cleaned and Painted.jpg
Old 04-10-2024, 09:32 PM
I also found a Paint Stamp that I think is Yellow FH Stamped upside down on the passenger side of the trans. Any opinions on if I am correct that it is FH?
Name:	Trans Paint Stamp.jpg
ID:	631893   Click image for larger version
Name:	Stamp position.jpg
ID:	631894   Click image for larger version
Name:	Stamp Length.jpg
ID:	631895   Click image for larger version
Name:	Stamp Height.jpg
Old 04-11-2024, 01:59 PM
I found some NOS vacuum A/C speed up switches that were MOPAR.
Only difference was the clocking of the vacuum port. I have no clue what application those are for.
Another oddity is the NOS MOPAR exhaust Y pipes with a MOPAR tag.
Agree with J.R. on the hat for exhaust bimetallic spring.
Fred may be a good source for pics of that as he snagged an NOS manifold many yrs ago.
Check the fan on the spines of the flex blades for stamped numbers.
I have an NOS 5 blade flex and thats where #s are..
My 67 OEM gasket for intake/exhaust was composite also and had part# stamped as well as McCord. Sorry for not responding sooner.
Old 04-11-2024, 02:08 PM
I believe FH is correct
I had a rubber stamp made and used the yellow paint out of my ball point parts paint marker
no need to be exact on placement,its an assembly line item
  #38
Old 04-11-2024, 05:38 PM
I forgot to mention that Ive been running a 67 A I R breather assembly on mine so I could convert to the 68 CCV.
That means there are at least 2 of these hens teeth left
ID:	631925   Click image for larger version
  #39
Old 04-12-2024, 12:40 PM
Gary, great to see another 67 AIR air cleaner survived! You don't still happen to have the FH stamp you had made do you? I was thinking of having one made with 1" tall 1/2" wide letters but if you still have yours I could borrow or buy it off of you.
  #40
Old 04-12-2024, 03:18 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
Quite the unique tear down!
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
