That's really nice. Congratulations.
No problems with detonation then? Looking through many posts over the years it seems many of those who have success with those pistons are using the 068 cam. Is the engine in a car yet or was it on an engine dyno? Glad to see another successful combo.
Fine job in keeping more gear heads coming and giving the old ones a outlet. |
This was an engine dyno and pretty noisy. Only severe detonation would be detected or damage to the spark plugs. So we were safe with the timing. Also the dyno was run at 170-180 degree constant water temp. Owner was warned of potential detonation with these pistons and to listen carefully once installed in the car. Students provide their own parts within their budgets. We provide guidance and explanations. He is a "cars and coffee" guy. It should be fine for his purpose.
The Following User Says Thank You to mgarblik For This Useful Post: | ||
Excellent results! Especially with those awful pistons!!
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of! |
Did you guys "zero" deck the block?
Did you calculate a compression ratio? |
Years ago, I took the Grocery Getter to a charity car show. Mike could not attend. I was approached by a mid-20's guy who introduced himself as a previous student of Mike's. His statement to me..."Mr. Garblik is 5 times better than any other teacher at Sinclair. We know, because of this car (pointing to the GG) that nothing he says is BS".
I love retelling that story. Eric
The Following User Says Thank You to Elarson For This Useful Post: | ||
As far as detonation my RAIV 400 had no audible detonation on pump gas nut as he said dyno is loud. Picked up 8 HP on race gas. Zero deck TRWs 69cc chamber.
I remember the block being squared in the surfacer, but I just can't remember if it was zero decked. I don't think he had the pistons at the time so I tend to think no. If I recall, we were a little surprised the heads cc'd at around 74 CC's after making them flat. I think the calculated compression ratio was right at 10:1. The rods were slightly short as they needed a fair amount of grinding to resize them properly. Overall, not absolutely optimal, but still a good serviceable engine. Had nice oil pressure, 59-62 PSI through every pull.
That’s a great stock rebuild nice work.
Note that picking up hp when going over to race fuel can also partially mean the race fuel specific gravity was more in line with what the jetting was, not only the need for more octane.
Neat build and decent power for what it is.
Probably just fine on detonation. If it were a problem even in a noisy engine dyno room, you would have seen it instantly on the dyno graph anyway. When they detonate the torque graph drops like a rock, very noticable. In the car with substantial heat may change things but if kept under control it'll probably be fine. My RAIII 400 is 10.13:1 with the 068 and it's been running fine on the 91 cat pee gas we have for years and likes 34 degrees of timing. |
Dennis |
Yes to cast rods, sort of. The engine had been previously worked on. Was standard bore but had an odd mix of several different runs of cast rods in it. Some were the typical cast rods with the support ribs near the big end we are all familiar with.. But 2 or 3 were of the early cast design from the mid 60's without the ribs. They were all different weights and lengths. So we swapped them out for a complete cast set that were "factory matched", and went from there. New ARP bolts, cut and honed. IMO, just hard to make a case for cheap aftermarket rods in an engine that is done making power at 5000 RPM's. Low cost cast pistons and pressed pins, still adequate for the purpose and build. Millions of those rods are out there doing their thing without poking holes through Pontiac blocks. Now running this combination to 6200 RPM's over and over like a SBC, and all bets are off. Owner made it clear this was a street only build. Cruise around on the weekends, run it through a couple gears every now and then.
The Following 2 Users Say Thank You to mgarblik For This Useful Post: | ||
The Following User Says Thank You to PAUL K For This Useful Post: | ||
I'm sure that all builds there get the max treatment concerning all build details. Removing sharp edges on piston tops and combustion chambers. Making sure the cam is dialed in. Checking all the lifters in each bore to make sure you don't have a "sticker". Preoiling the engine. Proper valve lash. Carb prep for a dyno pull.
There's many more but, I'm thinking this enging had a "Great" chance because of the instruction passed down from the teacher. I asked a lot of questions of my engine builder. Had them written down when I made a visit. He moved to another part of the state, and doesn't build common engines any more. I see him at NHRA events but don't talk to him much there, knowing how focused he is at a race...
