Cold Case in my Firebird has been excellent.
AC pulleys to overdrive water pump and fan. Should is key player here. Still have original on mine. Standard fan clutch with 7 blade AC fan from 76 TA. I have to be on highway to hit 170!! Most of the time it’s 165-168, even when it 90+ NOS AC Delco thermostat 170.(cracks open at 165ish) Had a cheaper two aluminum eBay unit before and It did not cool as good as cold case. That’s why I did every mod possible because I thought, The old two row aluminum rad was not the issue. It was two rows of one inch tubes. Sadly it was and when it began leaking I replaced With the CC. Stop at a store it heat soaks up to 185-190. And drops Back like a rocket to 170 before I leave the parking lot. Gerry.
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds Last edited by 68 Firebird; 09-06-2023 at 02:09 PM. |
Agree, I have no issue at all with Cold Case radiators. Good quality, fair pricing, and they work. I'm using them in 4 cars and they work, fit and function just as well as the expensive Griffins I run in the other cars.
It's the electric fan setup that stifles the radiators cooling ability, and there are dozens of other radiator vendors that sell those electric fan setups designed the same way. |
Is Rodney Red still around?
........I'm just learning as I go....... |
I ordered this from Summit:
https://www.summitracing.com/parts/SUM-384000 It took some minor trimming but fit in the stock 71 shroud just fine. Still using clutch-type fan.
The radiator is going on with stock shroud at first. I can't put any electric fan until I figure out how to hold the radiator. The radiator I have looks to be made by the same people who make Cold Case. Looks well made. Its 70 deg on a warm day where I live and it won't be street driven. If I can find a way to set the electric fan shroud I do have back 1/2"-3"4" it should help. I will try that before getting the Flex A Light 460$ fans. I might not have much of a problem since I live where its cool and I drag race it. https://www.amazon.com/RADIATOR-SUPP...omotive&sr=1-3 |
If this is track only then I see electric fan is the best option.
Tim Corcoran |
If you have a 70-81 F body, Restore-A-Musclecar makes one for about $125. I could not find another one that would fit.
