Good to see you found the issue. I think I used the Chrysler ARP flywheel bolts. Been a long time.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick. Best so far 9.95@135 mph. 1.39 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exhaust 950 Quickfuel. |
Jeff |
The real crime here is countless people have called and written to ARP telling them their flywheel bolts won't work for Pontiac. Not only do they not make the correct bolt but they continue to advertise and sell the standard head bolts to unsuspecting buyers.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
Hmm I am currently using ARP flywheel bolts, I’ll have to inspect em next time I pull the engine. Is this issue mainly with factory flywheels? I do have an issue sometimes shifting into first, every so often, much harder to shift into first at a stop. Rolling no issue
67 LeMans, 326, M20, 3.31 12 Bolt |
You can remove the trans, bellhousing and pressure plate and check the witness marks on the springs on the center of the disc. When I first saw that I took my 4 inch hand grinder and took off about 1/16th or less off the bolt face. When I changed engines I used the Mr. Gasket bolts.
1979 Trans Am WS-6 .030 455 zero decked flat pistons 96 heads with SS valves 041 cam with Rhoads lifters 1.65 rockers RPM rods 800 Cliffs Q Jet on Holley Street Dominator ST-10 4 speed (3.42 first) w 2.73 rear gear __________________________________________________ _______________________________ 469th TFS Korat Thailand 1968-69 F-4E Muzzle 2 |
Want to thank everyone for their input. Moved the car under its own power today for the first time since the mid-late 1980s I believe. Certainly the first time since I’ve owned it.
I always use factory fasteners. Head bolts, etc. Never had an issue running them for over 45 years in all my Pontiacs. If they check out ok, they get cleaned up and re-used.
Jeff |
OK, I'll buy that. Thanks for the explanation.
