Chris D 69 GTO Liberty Blue/dark blue T400, 9" w 3.50s, 3905lbs 461, 850 Holley, T2, KRE 310s, Comp HR288 w 165s, RA manifolds, 11.60@114, 1.58/60 The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60' |
OK that makes more sense, the way it read sounded like just the alum intake saved 100lbs.
If he ports the heads and intake, they`ll be even lighter.
Your motor is going to be similar to mine. I went with Edelbrock D ports. Unported but, my builder did do some clean up on them. Never been to the track but it runs very strong. It's a blast on the street..
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
There is not 100lbs difference between a pair of Pontiac iron heads vs aluminum heads. Not even close.
Now a big Rat engine with huge heads you might find 100lbs. Pontiac heads are puny in comparison. |
Going with aluminum heads and aluminum intake vs iron intake iron heads will definitely take off 100 lbs dam close, well ok maybe 98 lbs..LOL
From memory most aluminum heads are about 38 lbs. and iron 63. Wide ports are considerably lighter and make about 10 HP per pound lost when compared to a standard port aluminum head.
Do yourself a favor and lap the valves. If you don't know how find YouTube vids of it or pay someone
The Following User Says Thank You to slowbird For This Useful Post: | ||
Inflation is killer now days so the price to port them next year will be $$$$$$ more
Tim Corcoran |
Thanks Slowbird. Back around 74-75 I worked full time in an auto repair garage. The "old" mechanic there hand lapped the valves in a couple cast iron heads while I was there. I helped him with one set. That's about the lot of my experience with lapping. With the loss of feeling in my hands and questionable eyesight I wouldn't feel comfortable attempting to lap the valves in a pair of costly aluminum heads. I had planned to take the heads to a shop that specializes in head work to have them checked over before installation.
