Old 11-18-2023, 01:14 PM
Half-Inch Stud's Avatar
Didn't read this Thread at all. Regrets for the worn Exhaust Lobe.
Old 03-02-2024, 08:57 PM
OZZIEVILLE 67 2 door's Avatar
OZZIEVILLE 67 2 door OZZIEVILLE 67 2 door is offline
Update
I have been finishing brakes and suspension on the GP and was better just not chasing the misfire until yesterday, I thought one last test to confirm the suspected wiped cam lobe.
GP no start , no spark.
With ignition on, I have over 12 volts to thick red wire and no power to any of the 3 connections on the other plug.
Any tips please, I have a new addition to my automotive electrical inventory, a replacement for a very used 20 year old test light.
John L
Sent from my SM-X200 using Tapatalk
Old 03-03-2024, 11:37 PM
A bit more research tells me that the module could be buggered.
Thoughts and tips from the many master coaches.
JL
Old 03-04-2024, 02:18 AM
I could be wrong(ask wife) but those wires won't cause a misfire. A no start or cutting in or out yes but not a miss. Did you run car with valve cover off to see rocker arm movement? Messy but at idle and for only a minute or two. Ok re read your post you are now dealing with a no start right?
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
The Following User Says Thank You to salem1912 For This Useful Post:
Old 03-04-2024, 03:30 PM
Yep , engine was running and missing, now no spark,I have ordered a module.
Yes had checked valve train running.
JL
Sent from my SM-A426B using Tapatalk
Old 03-14-2024, 06:27 PM
New module installed, engine running and misfiring.
Final test as recommended in the elimination process to diagnose the misfire problem.
I will have engine running and spray wd40 over inlet and carbie gaskets to determine if sucking air.
Old 03-15-2024, 03:12 AM
Time to close my thread on this 350 Pontiac.
Final test was car running and spray the inlet gasket area on passenger side, Bingo !!.
Reves up sounds clean.
I realised the air is full of brake cleaner , I put the air cleaner back on and used wd40 ,picked up revs.
I did warm it up and drove it around the block 2 times risking huge fines due to no registration.
It drove like a slug.
The 350 is dead to me
It's got to come out .
My 67 Bonneville has a Pontiac Dude 1975 455 and that engine belongs in the 1976 GP.
I have the 1967 Bonneville 400 to rebuild and that just costs money.
Lucky I'm 65 nearly and got 2 years before I can maybe retire.
Lucky I got a community of Pontiac loyal enthusiasts that will steer a bush machinic like me.
I got a thread 76 GP Downunder that will continue the big job of engine out and engine in.
John L
