Old 10-22-2023, 05:56 PM
mgarblik mgarblik is offline
I think you are fine with that. I would run it.
Old 10-23-2023, 11:37 AM
chiefbigb chiefbigb is offline
I talked with the machine shop I use. They said full groove main bearings are not a requirement when using straight shot oiling.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 10-23-2023, 02:20 PM
We use 1/2 and 3/4 groove main bearings in Crower and Moldex billet cranks which have straight shot oiling. I like the extra support for the crankshaft in the cap area.
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
Old 10-23-2023, 05:46 PM
Gary H's Avatar
Gary H Gary H is offline
Try some Sealed Power main bearings. They normally measure quite a bit small than the Clevite's, thickness wise. They are 3/4 groove too. They may get you the extra clearance you're looking for.
Old 10-23-2023, 06:01 PM
tekuhn tekuhn is offline
Thanks everyone for the responses. I have one more bearing set on the way and I’ll decide after that what to do. Be watching for bearings on the Parts for sale page ��.
Hoping to finish a project while I'm still able to push the clutch in....
1963 Tempest Convertible (Ram Air IV w/4” stroke), TKX, 9-inch w/3.70 gears and triangulated 4-link) Pictures
Old 11-08-2023, 01:28 PM
cgeise's Avatar
cgeise cgeise is offline
Have the block main line honed to max spec. try diff brands of bearings, they all seem different
Old 11-22-2023, 09:31 AM
Tim Corcoran's Avatar
Originally Posted by tekuhn View Post
I installed the King MB5511XPSTDX and measured .0030" to .0035" clearance. Apparently they are sized slightly looser than the Clevite. I know the "rule" is .001" per inch of diameter, so I'm now on the loose side of acceptable. The crank is on the small side of acceptable at 2.9990. I could get a set of STD and close that up to about .0025" to .003". Suggestions?
Your clearance of .003 to .0035 is ideal you can't go wrong with those clearances.
Tim Corcoran
