Old 02-28-2024, 12:52 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Just depends if it picks up the bottom end or not and you need that or to lose a little on the bottom to hook.
Skip Fix
Old 02-28-2024, 02:19 PM
Tim Corcoran's Avatar
If you racing class racing and after every last HP your willing to risk longevity for winning races it's a different ball game. Most of us are bracket racers and on a budget want want it to last a while. In this case no reason to push the limits for a few ponies.
Tim Corcoran
Old 02-28-2024, 03:53 PM
grandville455's Avatar
grandville455 grandville455 is offline
4-5 hp u aren't gonna see anywhere, top or bottom, so no testing at the track with say 35 compared to 38-40? I don't see a car picking up much at all with 3-5 degrees more unless the combo is way off!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 05-27-2024, 09:13 AM
Kedavra Kedavra is offline
Sorry for posting this on the Race forum, but this is the most current thread I have seen specifically discussing the old Eheads.
After 3 rebuilds over the last 25 years, I have a now 468 (4.185 Mahles) 10.4 SCR but still have my old RP 87cc EHeads, reworked and refreshed, 2.19/1.77 lifted to 320/230 cfm, running a HR 242/250-112LSA@108, ported Perf RPM int (had Victor- wanted more low-end) now Sniper. Had a free but limited engine dyno (w/BG850) and little tuning time, but best runs were 610HP@5600, 640TQ@4500, and 550TQ@2500, Was dyno'd at 38 with race gas. did not have Vac Adv on last build but now have Sniper controlled Hyperspark. I am running at 36 WOT and high RPM, and 40 at cruise. AFR is set to 12.6 WOT up to 4700 then 12.8 WOT above that - this is a bit richer than the AFR from the dyno runs. Cruise @14.75, idle@14.2@850, I run Shell Nitro 93.
I have not been able to chassis dyno this yet.
I am trying to understand the best perf. but safe timing and safe AFR with these pre-02 Eheads 87 cc chambers.
Any advice appreciated!
Old 05-31-2024, 10:48 PM
blueghoast's Avatar
Each chamber has its place.... You can go far wrong with the CNC chamber. In our few "back to back" tests we haven't noticed much difference other than tuning requirements.
Same here, Don't notice any difference.
GT
The Following User Says Thank You to blueghoast For This Useful Post:
