Old 04-05-2024, 02:53 AM
lust4speed's Avatar
The Stump Puller comes in at 230/236 and the Old Faithful comes in one step higher at 236/242. While both are usually on a 112° LSA, there is enough difference that operating and performance goals should be considered before making a choice. Iron heads and the SP seem to go together well and a little better for tight converters. I know that Dave Bisschop usually recommended the SP for mild builds with iron heads.
Everybody copies everybody on cams and it seems that even the local deli probably carries a reasonable copy of either cam profile -- but I would suspect that SD Performance would still be selling cams even if it will be awhile before his shop is up and running.
Mick Batson
The Following User Says Thank You to lust4speed For This Useful Post:
Old 04-05-2024, 08:30 AM
grandam1979 grandam1979 is offline
Butler stocks this cam,
Old 04-05-2024, 10:56 AM
Steve C. Steve C. is offline
A FWIW, Butler lists those same XE hydraulic roller lobes ground with the 110 lobe separation as above, but also with a 112 & 114 lobe separation.
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
Old 04-05-2024, 01:35 PM
besserspat besserspat is offline
I had this cam , I want 112 and more lift .
Old 04-05-2024, 02:13 PM
jhein's Avatar
jhein jhein is offline
Butler makes that cam on a 112 and with 1.65 rockers that gets you pretty close.
Old 04-05-2024, 04:53 PM
The reasons why I want 112 minimum is because I spray 200 using a plate, the intake was going to be a SD CNC ported 71 HO intake ( that probably melted and burned down in his shop last summer , I couldnt get a hold of Dave since)
My heads are SD CNC irons he flowed at 270cfm, and my 461 is brand new built for nitrous .
Jakes performance th400 and Continental JH special ( 3200 tight ) converter with anti balloonjng plate.
Lust4speed , Dave told me last year he does not want to sell cams anymore. Otherwise I would have ordered from him at the time
Peter
Old 04-09-2024, 10:44 AM
I would trade that cam for a stump puller or the first version of the Old Faithful .
