Old 04-04-2024, 06:13 PM
soupman soupman is offline
Napster- I have the Exact same engine specs as yours, my CR is 9.8, same exact cam, I idle at 700 with mine but it’s a 5 speed in a light 87 Formula, it revs very fast. I had my 47 heads done by Steve25 to flow 250 and the car is scary fast, and will break tires loose on command. all the cam the motor needs IMHO. I have built 461 before and this is my 2nd 434, I prefer the 4” stroke.
The Following 2 Users Say Thank You to soupman For This Useful Post:
Old 04-04-2024, 06:56 PM
steve25 steve25 is offline
325 cfm on the intake side ( assuming your intake manifold can pass that ) has the potential with increased compression to make up for port volume to make 87 Hp per cylinder, or about 660 Hp.
That being said and as already posted with your cam 600 Hp can be had.
