Old 04-18-2024, 10:54 AM
Is your throttle stop/delay one that has you at an idle/set rpm then opens when ready to go, or on the mat and the 2 step keeps it at a set rpm until ready to go?
Nice dyno sheets!
Old 04-18-2024, 12:06 PM
Matt1970gto Matt1970gto is offline
Originally Posted by Stan Weiss View Post
Can you post dyno sheets for both engines?
What does each engine have for stall speed?
Stan
Nice dyno sheets!
My stop rpm is 3750 & remain in low gear while on the stop.
Old 04-18-2024, 11:48 PM
Stan Weiss's Avatar
What does your fathers car weight and what et does he dial?
Just a WAG using 3350# race weight.
1000 Foot ET = 8.4412
1/4 Mile ET = 9.9051
1/4 Mile MPH = 155.9576
Stan
Pontiac Pump Gas List
Old 04-19-2024, 08:52 AM
Stan
His car weighs 2750, mine is 2800 & change , I plan to weigh it next week @ the 4 wide . I am guessing I’ll be around 2825. We both run super gas 9.90. He’s usually 9.90 @ 158-160, with his single carb his best mph is 162.At the gators he was having issues & his mph had dropped to 155-156. I was running 157 there. & never making a clean pass. We have matching 1250 get’m carbs on both. Both cars have 3 speed lenco/bruno combinations. 2.08 1st for him, 2.24 for me & both have lightened 4.57 gears. Mine was built to be a twin to his but that never works out. Both have Bickel chassis as well.
Old 04-19-2024, 09:30 AM
Stan Weiss's Avatar
My simulations below 1000 foot with a throttle stop are way out. About 10 years ago here on PY I did do some simulations for someone who was running a .90 class. The idea for to see what MPH increase they would get from more HP but still running the same et. The simulations were fairly close.
Thank you for that information.
1000 Foot ET = 8.4739
1/4 Mile ET = 9.9008
1/4 Mile MPH = 160.2311
How close is my 1000 foot et?
Stan
Old 04-19-2024, 09:48 AM
Stan
Pretty close actually. Here’s a time slip from bowling green last year. I’m 2464 & killed 4 mph.
Old 04-19-2024, 12:36 PM
Stan
Dad is 2537 that was this morning at Reynolds Ga
Old 04-19-2024, 01:07 PM
aaronman aaronman is offline
Good luck down in Reynolds! You guys have them Pontiacs flying! Say hi to Dave P and Kevin M for me.
Old 04-19-2024, 01:12 PM
Stan
Dad & my sister made the trip. Our daughter had RSV & parainfluenza last week. It’s been a rough week or so here.
Old 04-19-2024, 01:44 PM
Stan Weiss's Avatar
Thanks. What is the weather? I pulled some HP and shorted the time of the stop.
1000 Foot ET = 8.4353
1/4 Mile ET = 9.8825
1/4 Mile MPH = 157.8409
Stan
Old 04-19-2024, 01:45 PM
Can you adjust the the time when the throttle 1st close? (like 1 second into launch)
Delay closed is around 2 seconds?
Also actual carb being throttled or a butterfly in spacer under carb?
Hope your daughter is better.
Old 04-19-2024, 02:06 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
Sorry your Daughter is not feeling well
I lined up with Laurel on a Time run today.
Sounds like the headers are too big. Try adding the extension to see what happens. Maybe after Charlotte, ask dad if you can try his intake. lol
Dave Polichena
Old 04-19-2024, 03:41 PM
I wish I could try his intake & headers..
Old 04-19-2024, 03:43 PM
Your mph is down , your wedge motor not wedging?
Old 04-19-2024, 03:47 PM
Yes, I have timer one set to come on @ 0.005, this is a carb with under the carb stop but I also have a APD maxspeed with the stop made in the carb.
Old 04-19-2024, 03:56 PM
I don’t always claim Laurel & most dont know me on here yet so don’t give them clues lol.
Old 04-20-2024, 10:56 PM
Stan Weiss's Avatar
Hope your daughter is feeling better.
Maybe someone else will look at this and see it as one thing. I don't know what it is, but think it has to be a combination of parts.
Stan
ID:	632395   Click image for larger version
  #38
Old 04-21-2024, 08:39 AM
slowbird's Avatar
slowbird slowbird is offline
Stan
I agree Stan, I think it's a combination of parts that's causing his issue, not 1 part.
  #39
Old 04-21-2024, 09:14 AM
Stan
Both times I’ve had it on the dyno the guy said your problem is that 55 gallon intake you have. It barely made 1000 hp the first time. We changed cam & took some plenum area out & made 1071.9. I’ll message the guy again for the intake scan information. Not the best pics but here is a before and after of the inside of my plenum.
  #40
Old 04-21-2024, 10:04 AM
Stan
Here is the pic not cropped of how it was when I got it. We thought the plenum area was huge right off the bat. Sent pics to Don & he disagreed thinking it may not be big enough.
