Old 05-21-2024, 11:27 PM
Held for Ransom's Avatar
Has anyone else noticed 2 different styles of sleeve on the front inner seat belts?
ID:	634083   Click image for larger version
So long, farewell.
Old 05-21-2024, 11:30 PM
It could be because of huge gap in weeks between the 2 sides.
ID:	634085   Click image for larger version
ID:	634086   Click image for larger version
ID:	634087   Click image for larger version
So long, farewell.
Old 05-21-2024, 11:33 PM
Back seat tags.
Had a couple pictures mixed up...
ID:	634089   Click image for larger version
ID:	634093   Click image for larger version
ID:	634094   Click image for larger version
So long, farewell.
Old 05-23-2024, 03:04 PM
Transamric's Avatar
Transamric Transamric is online now
I have to love that original, holey Oldberg muffler. don't see too many "survivor" Oldbergs these days. In any condition.
Old 05-23-2024, 04:53 PM
Old 05-23-2024, 04:58 PM
I was mad when I realized I never took photos of the one I pitched that was in the '74 Formula.
Still wears spiral shocks. Rear assembly date. And, even though the gas tank was replaced, it still wears the original gas cap.
ID:	634171   Click image for larger version
ID:	634172   Click image for larger version
ID:	634173   Click image for larger version
So long, farewell.
Old 06-23-2024, 11:03 AM
Pepi's Avatar
Pepi Pepi is offline
Nice purchase!!!
I believe my front seat belt sleeves are like that also.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
Old 06-23-2024, 11:23 AM
Pepi's Avatar
I remember mine were all pretty close except for 1. Most of them were within the first 5-7 weeks of 73, but one was the 16th week and my car had a ship date of 04C. So what, did the seat belt hold up shipping? Sorry for the poor quality photos, took them about 5 years ago.
ID:	635758   Click image for larger version
ID:	635759   Click image for larger version
Old 06-30-2024, 09:31 PM
Formulabruce's Avatar
Back in the 70's there was a company. ( Mr Gasket? ) that made a metal donut so you could run a 4bbl "v-8" air cleaner on a 2bbl V-8 car. Saw them at Carlisle in the early 80's a few times too. Just a thought..
Another is keep the 2bbl as " dual Jet" 200, which will run a 4bbl air cleaner....
" Long may we DRIVE !"
Old 07-01-2024, 06:35 AM
HWYSTR455's Avatar
WOW! Congrats!
Old 07-01-2024, 07:36 AM
cnc's Avatar
cnc cnc is offline
Formula had the thin one, Esprit had the fat one and Trans Am had none. Base Firebird, I'm not sure on if there was an option and what it would have been.
Nice Purchase HFR …..…beautiful car…..just to add My Firebird is a base with the thin rocker trim…..My frt belt sleeves appear to be the same ….
ID:	636170   Click image for larger version
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 07-01-2024, 07:47 AM
cnc's Avatar
cnc cnc is offline
My Firebird is a base with the rocker trim
Old 09-21-2024, 07:08 PM
He (or someone) already incorrectly opened up the snorkels on the hood, so I may be working on a 2 bbl based Ram Air air cleaner (I'll be using the repop unit I have, not the NOS). But it's tricky as the bases floor are different between the 2.
Well, I pulled the trigger and cut up the repro. and a 2 bbl. (ruined unit) air cleaners and married the two together. Will get it cleaned up in the next week.
So long, farewell.
Old 09-27-2024, 07:30 PM
Out with the old, in with the new (for now). Even took a little "medical prescription" making the label.
I need to reach out to a certain member to see if he has the "kit".
ID:	640605   Click image for larger version
So long, farewell.
Old 09-29-2024, 07:32 PM
Members are asking about vacuum hose colors, so I'd thought I'd show them on this car.
EGR to upper valve nipple - Black
Lower valve nipple to carb - White stripe
Charcoal canister to carb - text, EVAP 1/4
Carb to back of carb tee - Yellow stripe with text (scratch my head on this one)
Manifold to PVC valve - Purple stripe (may be White stripe)
Distributor vacuum spark thermal valve upper nipple to front of distributor vacuum control valve - Green stripe with text
Distributor vacuum spark thermal valve lower nipple to tee - Red stripe
Tee to air injector - missing
Tee to air cleaner - White stripe
Air cleaner to AC Therm vacuum valve - White stripe
Tee to back of distributor vacuum control valve - Yellow stripe with text
Distributor vacuum control valve back to spark advance vacuum delay valve - Green stripe with text
Spark advance vacuum delay valve to distributor - Green stripe with text
ID:	640718   Click image for larger version
ID:	640719   Click image for larger version
ID:	640720   Click image for larger version
ID:	640721   Click image for larger version
So long, farewell.
Old 09-29-2024, 07:34 PM
Missing picture to other post and
Choke pulloff to carb - White stripe
ID:	640725   Click image for larger version
So long, farewell.
Old 10-01-2024, 12:51 PM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
Wow, fantastic find. Incredible you can still purchase something like this in 2024. I'm sure it'll be a fun project. Appreciate all the documenting of how the car is built/configured.
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
The Following User Says Thank You to thefirebirdm@n For This Useful Post:
  #38
Old 10-01-2024, 05:07 PM
wwilder9's Avatar
wwilder9 wwilder9 is offline
Congrats
68 Firebird Coupe 350/Auto/Air
70 RA III Formula/Auto/Air
71 T/A 455HO/Standard/Air
73 T/A 455/Auto/Air
  #39
Old 04-27-2025, 03:21 PM
Came across the odometer picture before I purchased it. Notice how straight the numbers are.
So long, farewell.
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post:
  #40
Old 06-15-2025, 05:15 PM
Here are a couple pictures of the spare mounted for that showroom look (even though it has the metal lower valance). Tire was left jacked up to show tread so tire-fender gap looks off. Notice POWER BEAM headlight.
ID:	652973   Click image for larger version
So long, farewell.
The Following 3 Users Say Thank You to Held for Ransom For This Useful Post:
