You could run a vacuum pump. Its bolt on.
A lot harder for a engine to leak with negative pressure in the crankcase. My last engine, no leaks. Well sort of. I had a leak from a valve cover due to those inexpensive top bolt fabricated valve covers. They have a lip that holds oil on the bottom rail. Cured it with a little Permatex #2 along that bottom rail. All my engines have leaked a little until now with the V pump. |
| The Following User Says Thank You to Dragncar For This Useful Post: | ||
It was easier for me to smoke test the engine on the stand than in the car, but it worked in the car just fine. I also had a giant gaping hole in the rear main so there was plenty of room for the smoke to escape. Might be harder to see with smaller leaks. You should definitely take the inspection cover off, too.
I have some dye in my T/A right now trying to chase a leak. It takes a little more detective work than the smoke tester. Clean the underside off of any oil before you put the dye in and check underneath it frequently after a few short drives. If you dump the dye in and drive around a lot it will be harder to chase the origin of the leak since the oil gets blown around. After my second rope rear main failed, I was looking at the machine work on my block (it was line bored) and the straightness of the crank. I never got a definitive answer on what ate them up, but I'm fairly certain it was the serrations on Eagle crank. I had the crank and serrations polished and carefully installed the BOP. Fortunately I've been leak free since (knock on wood), however I do get a tiny bit of oil residue around the rear main after a few hundred miles. I've been watching it like a hawk. The BOP seals take a bit of work to install, but they have a reasonable amount of tolerance built into them if you fit them to the block correctly. I think it's -/+ .005. I guess my point is I think your block has to be pretty bad for the seal not to work.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
Thanks for that info Ken...............i think i got to get a better black lite other than the cheaper i have, its like a little pen lite deal, i have the stock crank in the car, not 100 sure but i think the block was line bored somewhere along the line............motor was done in 2007, then re-done in 2010............cant really complain after the two rebuilds it never leaked on the ground although the inspection cover always had oil in it............had the motor re-ring last year, this is the first time i had oil leaking on the floor though.
This has been really frustrating for me.............i pay good money for top notch parts and get half ass results..............not sure which way im gonna go with this, but i do appreciate all the help i get from you guys. FYI............the reason i had the motor re-done in 2010 was due to very excessive oil consumption..................last year i was blowing so much smoke out the rear, i got it re-ringed Other than that the motor runs great, never let me down in 20 some years..................just gotta come up with some plan. Rich |
Maybe there’s someone in your area who can properly install the main seal for you, and handle the short block assembly as well. Even if you have to drive all day to drop it off with someone who’s calm and collected when it comes to these sort of things it’ll be worth it.
This would be after you have the block inspected for possible casting porosity and concentricity of the main seal groove to the main bearing bore. Someone who’s very familiar with precision measurement needs to do the inspection, there are instances where the seal groove is too far off to use the BOP one piece seal. I paid someone who was more experienced, better equipped and just plain better at engine building than I ever will be and it was worth every penny. |
| The Following User Says Thank You to b-man For This Useful Post: | ||
[QUOTE=gtorich;6507780]
I had the same type of leak on my 467 stroker build, I had my local shop build the bottom end & install the BOP 2 piece seal, I installed the rest of the engine including the oil pan, used the OEM rubber "U" seal, had leaks like yours right away & looked like it was from the rear main, I cleaned it with brake clean then let idle for a couple minutes & it would drip again, cleaned it & let sit overnight & had drips. I pulled the engine & brought back to shop for new RMS, had them install the pan this time, got home & it leaked way worse, like a 5" spot on the ground instead of a few drips, (I installed the pan gasket better the 1st time!) So pulled it out again & brung back to shop, they said the prev RMS looked fine but this time I had them use the cork gasket & ultra black sealer like Mr P-body suggested and I sent you the link of how to do it, been mentioned on here before too, got a free dyno run to verify no leaks & did a few pulls just to see what HP was... was leak free this time & still is drip free after 8-9 years. It will "seep" a bit after months of driving but just wipes off with no drips or leaks. My advice is the same as last year, use the cork gasket for the rear U seal, & consider a standard felpro gasket instead of the 1 piece, & be sure to use the rear corner tabs. As a band aid you can try a good sealer like ATP305 or even bars rear main sealer along with a high mileage oil to see if that helps. Best of luck! Last edited by 78w72; 06-07-2024 at 10:18 AM. |
| The Following User Says Thank You to 78w72 For This Useful Post: | ||
Just a side note concerning using a smoke machine for leak testing. I have 100% success finding a leak using them. But you need to smoke test the engine without oil in the pan. It can have a quart or so in there, but not full of oil. If the leak path is submerged, the smoke, under the very low pressure can't push the oil out of the way and smoke out.
| The Following 3 Users Say Thank You to mgarblik For This Useful Post: | ||
I remember this well from last year my friend.................lol...........i thought it was fixing itself, looked good for awhile but now its getting worse..........couple pics for you here but hard to see anything, i cleaned up stuff today, hard to believe with oil everywhere except the rear bumper.........ok not that bad. Hard to tell from the pics but i can see where i put some right stuff along the edges of the bop gasket, just didnt use the cork gasket in the grove..........seems im getting a little oil in the bellhousing by the clutch, wasnt there last year. Was thinking today, just sell the car at a loss and be done with it...............but i have 25 yrs with it, just hard to let go, but this pulling motor for the 4th time is really getting old. and im still worried its gonna be the same old song and dance, leaking oil. As per Barts note, to find someone to put this together with the rms.............im not doing this on my own, these are shops doing it. Im gonna drive the car this summer and hope for the best....................hoping a motor will pop up on the forum that isnt insane compression level................tried a couple times with bulters, but everytime i call they say no more motors for this year............. I guess im really getting old, i read, just pull it, no big deal..............well im not thinking along those lines.............lol Well anyways, few pics, not sure you can tell anything one way or the other. Forgot to mention............really couldnt tell if any oil was on the front of the flywheel...........looked liked there might have been some, but i figure it got flinged off..............will post a pic of where i drilled a few holes in the inspection plate, thought this might be better than oil staying in by the clutch area...........thinking this might be worse for driving as i said oil is all over my trans and exhaust from driving. Rich |
My mother was always encouraging me with auto and other related projects when I was young, had no problem grabbing tools, getting dirty and enjoyed the process along with me. She helped me carefully remove and tag the entire interior out of the '59 about 12 years ago. Last edited by 59safaricat; 06-07-2024 at 06:44 PM. |
Rich |
Wow, she is amazing.
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
I fought a leak for most of last year after getting my engine back from a machine shop that was strictly a rip-off joint.
5 times I pulled the motor and resealed the oil pan, believing it was the cause and not the main seal. Turned out the shop lost all it's staff and was conning everyone that they were still in business...but that's another story... By the 5th time, I changed my strategy and figured out a way to test the rear main seal for leaks. After cleaning up all the oil sprayed around by the flywheel, I took some 1" strips of paper towel, folded them over a 1" paint scraper and pushed them up behind the flywheel flange. Then I used my shop vac to push air into the oil fill hole on the rocker cover for 30 seconds. This slightly pressurized the crankcase. When I removed the paper towel strips, they had oil on them, confirming it was the rear main seal leaking. Turned out the con shop never read the instructions for the 2-piece vitron seal, and never sealed the anti-rotation holes with silicone prior to installing the seal. They also never replaced the rings that they charged me for, and over-torqued the main caps ruining the bearings and the caps. I can't even be sure they replaced the bearings as they did not return any used parts. For the oil pan I used a new Milodon 7 quart pan and test fitted it using a feeler gauge all around to get it just right. Then I used Butler's one-piece gasket, but removed the rubber 3-prong section. Instead I made a 1" wide, 1/4" thick piece of rubberized cork out of 2 pieces 1/8" thick cork gasket. (Typical Felpro gasket pack) I siliconed the 2 pieces together, and taped it down over my bench grinder motor , so it will set in a curve to match the pan and rear cap. Once dry it was just a matter of trimming to fit, a bit of silicone where it meets the Butler gasket, a bit more to seal the slots in the pan and no more leaks. As for the rear main seal...the short block went in to a reputable shop, and I supplied a Butler 1-piece RMS, which was properly installed this time. The crank was polished, it was line honed, caps were repaired, new bearings and rings, and everything was weighed and balanced. For the first time in 5 years, I am not leaking or burning oil, and the oil stays clean. |
I have the 7qt milodon pan too, it uses the same older 3 prong U seal as the older late 60's pans vs the later 70's pans with 5 prongs. The later U seals are better than the older ones, from what Ive read the older U seals are notorious for leaking, the bead can roll if not installed exactly right & that causes leaks that look like a rear main leak.
wh33lman used the 1/4" cork gasket also with good results, I still say thats where your leak is from Rich.. providing the RMS was installed right the last time. I know pulling the engine is a huge hassle, I pulled mine 2 times after the initial install to fix the leak that was definitely the pan U seal. I wouldnt want to selll a car just because of a leak, looks like with your Mom's help you should be able to do a basic engine pull, leave the trans installed if you can for less work... then do the "tip test" before installing it again to be sure its leak free. Or pay a good shop to do it if you have the funds & dont want to mess with it yourself? On these big cars, cant the pan be pulled with engine still installed? Its harder on your back but can be done. |
When I removed the paper towel strips, they had oil on them, confirming it was the rear main seal leaking. Turned out the con shop never read the instructions for the 2-piece vitron seal, and never sealed the anti-rotation holes with silicone prior to installing the seal. Good tip, im gonna try this..................will also try to get a smoke machine..................the shop that did the work said they smoked it, by there work i think he meant he smoked one, but didnt inhale. Scott, i think you might be right on that oil pan................this time i will use the cork piece i bought to put in the groove. Another question i cant seem to get a answer from is "What if the shop didnt fill the anti-rotational holes" would that contribute to some leakage...........idk. From what i read, its possible to change the oil pan gasket..................but most say way easier and to do a better job, pull the motor. Once again appreciate all the help i get from you guys...............had the car out today, runs perfect, well except for the drip, drip.........lol Rich |
| The Following User Says Thank You to gtorich For This Useful Post: | ||
I bought the ME Wagner PCV valve and it helped with oil leaks a fair amount. I used a cheap manometer from Amazon, and confirmed that I was getting more negative crankcase pressure at idle and cruise with the ME Wagner than I was with a couple of different over-the-counter PCV valves. It's not cheap but it's worth a shot.
Still - those oil leaks you have are no big deal. Drive your car! |
| The Following 3 Users Say Thank You to i82much For This Useful Post: | ||
I’d kill to have a leak that small
| The Following 3 Users Say Thank You to 64speed For This Useful Post: | ||
I had a leak from the oil pan at the rear. It wouldn't leak cold. It would only leak when the oil was hot and thin. I've heard of using heavier weight oil, like straight 40 weight, running the oil a little low too. I installed a ME Wagner PCV which I think helped. I also considered adding a vacuum pump. Suck those drips back in. Just yesterday, I dropped in a 455 with the BOP one piece rear main and the one piece oil pan gasket with a new oil pan, the 64-69 style. Ultra black RTV in the corners and along the bend over the main cap. The pan doesn't have the alignment slots and has a raised bump along the curve for the main cap. The bump really pushes into the pan gasket hard. So far, drip free.
#38
Maybe a long shot but did installer forget to put anaerobic sealer between rear main and block?
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
| The Following User Says Thank You to grivera For This Useful Post: | ||
#39
Im trying a few suggestions i got from my two posts about this, then figure out what my next move is. Rich |
#40
In all my years and 5 engines in my 73 TA, it has always had oil leaks. Even using the latest greatist rear main seals, pan gaskets, valve cover gaskets etc. and permatex goup. Always had a fog of oil on the car chassis and small drip. Did some research on my breather PVC system and bought a Wagner dual adjustable PVC valve. Seems to have cured the problem. Poor mans evac system!
