Old 08-25-2024, 02:44 PM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
Most folks don’t want an idle speed of 12-1500. Even the factory put smaller WP pulleys on the A/C cars vs non A/C cars.
The Following User Says Thank You to 65 Lamnas For This Useful Post:
Old 08-25-2024, 03:34 PM
Originally Posted by 64speed View Post
I am using the 66-67 style drivers side inlet is what I mean. It is the smaller core (15 inch) but the inlet is on the drivers side. That was the first solution offered me by Cold Case when my first engine wouldn’t cool at all.
And I’m sure it’s likely the best radiator they could have sold you considering the major constraint being the standard 15-1/2” core support. The coolant flowing diagonally is a little better design than the original ‘64-‘65 with both hoses on the passenger side.
When I called Cold Case they recommended the Severe Duty twin 1-1/4” tube radiator that only came with the ‘66-‘67 inlet and outlet that only fits the 17-1/2” core support. I don’t think the Severe Duty radiators come in any other configuration.
Unless you’re into swapping core supports or upgrading your current one to 17-1/2” you already have the best radiator for your situation and honestly it’s not really working all that badly.
Old 08-25-2024, 06:57 PM
geeteeohguy's Avatar
197° in traffic with the AC on? Pfft that's not a problem.
Agree 100%. He's chasing ghosts.
Jeff
The Following 3 Users Say Thank You to geeteeohguy For This Useful Post:
Old 08-25-2024, 07:35 PM
Schurkey Schurkey is offline
My idle rpm is between 850-900.
Raising his idle speed will provide the same result as the above and consume less power when the vehicle is moving.
Thank you. I'd be mildly unhappy with an 850--900 rpm idle, let alone raise it higher.
Old 08-25-2024, 07:48 PM
There’s a good reason why the air conditioned cars all had a smaller diameter water pump pulley.
I forgot the reason…..
Old 08-26-2024, 08:10 PM
CYNHIKER CYNHIKER is offline
b-man, do you have the part number for the Cold Case Severe Duty radiator?
Old 08-26-2024, 09:12 PM
GPG38AS
I checked their website and saw GPG38A but I’m thinking the S added to the part number is what designates Severe Duty with the 1-1/4” tubes. Keep in mind my application is for automatic transmission.
https://www.coldcaseradiators.com/pr...tor?sku=GPG38A
Call sales at Cold Case to confirm but that should be the same exact one I purchased.
Old 08-27-2024, 02:09 AM
dataway's Avatar
dataway dataway is offline
When I was 20 years old and my GTO was a daily driver, on really hot days ... I'd just put it in neutral when I came to a stop, usually the extra 200 rpm or so was enough to keep it cool with the AC on.
Old 08-27-2024, 08:12 AM
Gary H's Avatar
Gary H Gary H is offline
And, if an automatic transmission, helps by not loading the convertor which builds heat.
The Following User Says Thank You to Gary H For This Useful Post:
Old 08-27-2024, 08:36 AM
steve25 steve25 is online now
Hey gang, he’s got a manual trans !!
I can’t see why an increase of 150 rpm is an issue to reset the carb or FI to for just the hottest summer months.
Maybe even just 100 rpm more then his current idle speed will give him the non temp increase he’s looking for.
Old 08-27-2024, 09:09 AM
VCho455's Avatar
VCho455 VCho455 is offline
Maybe his problem is being caused by hot air from the radiator being recycled back through the radiator when the vehicle is stationary. Our cars were not designed to sit in today's traffic. New cars are engineered to prevent or at least minimize hot air being recycled through the radiator.
Old 08-27-2024, 09:51 AM
carbking's Avatar
carbking carbking is online now
The easy solution is to place a piece of electrians tape over the temperature gauge display!
Jon
The Following 5 Users Say Thank You to carbking For This Useful Post:
Old 08-27-2024, 09:55 AM
242177P's Avatar
242177P 242177P is offline
Originally Posted by VCho455 View Post
Maybe his problem is being caused by ...
His problem is the digital readout. You can watch
the temperature rise degree by degree. It went up.
It went up. It went up. Cars were never meant to
stay at a fixed temperature, and using the AC on a
hot day is gonna make it move. Can't remember
which desert we crossed, but it had signs warning
against using AC. I wonder why...
Old 08-27-2024, 05:15 PM
STEELCITYFIREBIRD's Avatar
Do you have a fan shroud?
My thought process is to increase fan efficiency at lowest rpm.
An idle speed ‘booster’ solenoid is how engineer's combated this issue…what do they know 🤔
Old 08-27-2024, 06:39 PM
jhein's Avatar
jhein jhein is offline
From what you said, it sounds like you're not worried so much about the 197 temp but more worried about the fact it may keep going up until you overheat. If that's the case, just test it. Get it fully heat soaked then return to your driveway and let it sit and see what happens. You may find that it will reach a limit and not overheat.
I don't have AC but here's what my car does. I have a OEM style radiator 180 deg thermostat and a flex fan (not sure of the diameter) and a factory shroud. The motor runs at 180 at all times while moving at any speed. At a stop, it will climb up to about 190 fairly quickly. But, it never goes higher. I almost never have to stop for more than a couple seconds at a stop sign but every now and then there's road work going on and I may have to stop for a couple minutes. The first time I watched my temp climbing up quickly I got a bit nervous. But then once I got moving again it came right down. So anyway, I tested it like I described and it climbs up to maybe 190-195 and just stays there. Doesn't keep climbing. So give it a try and see what happens.
Also, are you running vacuum advance? If so, is it connected to ported or manifold? Manifold will run cooler at idle. Also, depending on your driving conditions, radiator fins can get clogged up with bugs and debris that can affect cooling especially at a stop. Probably not the case with your car but you never know.
The Following User Says Thank You to jhein For This Useful Post:
Old 08-27-2024, 08:02 PM
64speed's Avatar
64speed 64speed is offline
Exactly! I am wary of finding out what my upper limit is.
The Following User Says Thank You to 64speed For This Useful Post:
Old 08-27-2024, 08:22 PM
By staying with the 15-1/2” core support you limited yourself to not only the smaller radiator with 1” tubes instead of 1-1/4” tubes but you’re also missing out on the larger 19-1/2” fan.
If you want the additional peace of mind and cooling capacity of the bigger more efficient large tube radiator and 19-1/2” fan plan on spending whatever it takes to replace or modify your core support and upgrade your cooling system.
It’s not a big deal finding out what your upper limit might be, don’t be shutting it off at 197 let it hit 220 before you shut it down next time. 20 minutes sitting in traffic with the air conditioner running and only hitting 197 seems like you’re doing fine to me.
  #38
Old 08-28-2024, 12:29 AM
jhein's Avatar
That's the source of your stress right there! Man, have I felt it. You could correlate my heart rate to my water temp gauge. Test it and see. Maybe (probably) it's fine. If not, you need to know,
  #39
Old 08-31-2024, 02:18 PM
64speed's Avatar
If I buy a condenser fan do I want it to push or pull?
  #40
Old 08-31-2024, 03:34 PM
242177P's Avatar
An extra fan is no magic bullet. If it
can't move at least as much air as
your existing fan I'd wager you just
created an airflow restriction.
