![]() ![]() Wow, what a blast from the past! Actually, it's very timely. I took my ac belt off years ago when drag racing, and I lost it. I couldn't remember what size it was until I saw the post you linked. In that writeup I included the belt size - 59.5"! Thank you sir! My racing days are all done, so I am making the Bird a little bit more comfy. Yeah, that CAA bracket still seems better suited to mount a 50 cal Browning M2.
| The Following User Says Thank You to Squidward For This Useful Post: | ||
That’s a great thread! Haha
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
Sounds like there's a few ways to go but pro6ten compressor and parallel flow condenser seems the easiest to upgrade.
66 Lemans build https://forums.maxperformanceinc.com...d.php?t=876235 |
I like the newer sanden compressors, I've used quite a few.
Yeah they take less HP to turn but that comes with a price. They also don't pump as much as the old A6 does. A proper working A6 is one hell of a freon pumper, the internals are much larger, they simply move more freon than any sanden will. The sanden will get the job done though and is a nice way to go if you don't have a good working A6 |
A note. The pro6ten compressor comes filled with oil compatible with R134 Freon. If you decide to use R12 you need to drain it and put in R12 compatible oil.
Jeff |
Moving in that direction with the Mk IV
I'm using the Pro6Ten compressor to utilize the factory mounting brackets.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
