Old 12-03-2024, 08:17 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
Does anyone have the felpro part number for the Pontiac thermostat gasket? The last time I needed a gasket I had trouble finding the number for just a gasket. Had to pull one out of a kit.
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
Old 12-03-2024, 08:44 AM
64speed's Avatar
64speed 64speed is offline
Pm me your address I’ll send you one.
Old 12-03-2024, 10:56 AM
burd burd is offline
My OG was alum, I do have an extra for sale.
Old 12-03-2024, 04:50 PM
Dragncar Dragncar is offline
Originally Posted by 68WarDog View Post
Are there any other brand of thermostat housings that will work on our Pontiacs?
This is the best one I have found.
http://nitemareperformance.com/waterneck-pro.html
Name:	Screenshot 2024-12-03 at 12-49-03 Nitemare Performance - Billet Pro Water Neck.jpg
Old 12-03-2024, 06:40 PM
Dlaw455 Dlaw455 is offline
That is a nice one. I got a nice Canton billet one. It has an Oring which sealed perfectly after I experienced nothing but leaks with the cheap cast version. It does go straight up but is fine compared to the 15deg from vertical stock one.
Old 12-03-2024, 07:51 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Thanks Dragncar, that's a nice piece., and USA made.
Old 12-04-2024, 08:09 AM
Holeshot71's Avatar
Hey thank you for the offer! I’ve actually made a couple extra with some gasket material so I’m good for now. I was hoping to get the felpro part number because they use to be available specifically for Pontiacs with the correct bolt spacing. Seems like the only ones I could find were a universal style with slotted holes.
Old 12-04-2024, 08:21 AM
64speed's Avatar
Old 12-04-2024, 09:23 AM
grivera's Avatar
grivera grivera is offline
I’ve used both the aluminum and cast iron water necks and haven’t had an issue with leaks ever since I started sanding the gasket surface to ensure flat, using the Permatex thermostat and waterpump RTV (no gasket), and not over tightening.
https://www.amazon.com/Permatex-2207...35178778&psc=1
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 12-04-2024, 03:54 PM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
If anyone was curious, like I was, it appears no aftermarket T-stat housing gaskets are Pontiac specific, they’re universal slotted hole jobs.
If one wants a dedicated gasket, one has to patronize Butler, KRE, BOP, etc. as they all appear to have them. Probably all made by one place, TIP I would assume?
costs too much
Old 12-05-2024, 09:08 AM
dataway's Avatar
dataway dataway is offline
Eventually I'd like to add a laser cutter to my shop, sure would be nice to be able to cut gaskets out of any material you want, sized perfectly to any application. Laser cutters capable of cutting gasket material are well within the $1000 price range.
Old 12-05-2024, 02:00 PM
69Customs's Avatar
69Customs 69Customs is offline
I use a chevy chrome housing with the o ring. Only modification was to use a rat tail file and elongate the mtg. Hole pattern out a little bit for pontiac bolt pattern. The amount is so small that the bolt heads still cover it. Also I use 240 sandpaper on flat steel sanding block to make sure it's good and flat
Old 12-05-2024, 02:30 PM
78w72 78w72 is offline
These chrome T-stat housings are usually a universal fit for most GM vehicles that use this angle housing, on all the Mr Gasket ones I used they didnt say pontiac on the package but never had to elongate the bolt holes, they mount to a pontiac intake without any issues in my experience.
But, looking at summit, they have a Trans-Dapt brand that says its for pontiac V8, most others say for big/small block chevy...
https://www.summitracing.com/parts/trd-9230
Old 12-05-2024, 05:08 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
CSR used to make an adjustable aluminum Pontiac one.
Skip Fix
Old 12-06-2024, 01:36 PM
dataway's Avatar
I have the solution, I modeled and printed up a universal thermostat housing.
ID:	644040   Click image for larger version
Old 12-06-2024, 02:58 PM
tempest1964's Avatar
tempest1964 tempest1964 is online now
Franken.... What?!?!?! Lol
The Following 2 Users Say Thank You to tempest1964 For This Useful Post:
