Old 01-03-2025, 10:59 PM
limejudge69's Avatar
x2 on adding more shims. A small section of coat hanger works great as a go/no-go gauge. GM starter shims are usually found in the Help! section of your local auto parts retailer.
Old 01-03-2025, 11:52 PM
misaac misaac is offline
IMI for over 10 years. 455 D-port with Dougs headers. No problems
Old 01-04-2025, 12:39 AM
Dragncar Dragncar is offline
When I first got my Summit starter the instructions said to tilt-cant the starter with washers. Set the clearance of the teeth at 1/8".
Works great. Never had any luck with shims.
Old 01-04-2025, 01:05 AM
chuckies76ta's Avatar
I'm just in the process of replacing my flexplate and the Power master 9510 starter. Follow the instruction on there website. https://www.powermastermotorsports.com/starters1.html
The clearance on this starter is listed at .100-.125 and the teeth at .020-.035. https://www.powermastermotorsports.c...3_GM_Denso.pdf
Like mentioned get some extra shims or use washers to get it where it needs to be. You can always have a custom spacer made after and install it, if that's works for you.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
Old 01-04-2025, 12:06 PM
Tom Pugh Tom Pugh is offline
yep, I think thats the trick.
Old 01-04-2025, 12:09 PM
yes, the spacers supplied just don't get it done for me. A thicker spacer or washer on one side would likely move it away from the ring gear.
Old 01-04-2025, 01:14 PM
I also have the IMI starters. The gear end play on them is .020-.030. Reason I'm mentioning this to you is that I believe this is what caused my last TCI flexplate ring gear damage. I had it set at like .075-.090 clearance. What happens over time is, it can destroy the ring gear on the flexplate.
https://goodvibesracing.com/Technical/IMI-108.PDF
Little video from summit showing installation. https://www.youtube.com/watch?app=de...8dsG7Ls&t=196s There saying .040 clearance. + or - .015.
Too get these clearance, there saying get a paper clip or you can use a safety pin. Measure it with your calipers to find one that has the proper thickness.
950 Quickfuel.
The Following User Says Thank You to chuckies76ta For This Useful Post:
Old 01-04-2025, 01:36 PM
Here is what happens to the ring gear on the flexplate when the starter gear is not engaging properly.
ID:	645683   Click image for larger version
950 Quickfuel.
