Old 02-17-2025, 06:00 PM
Dragncar Dragncar is offline
Originally Posted by i82much View Post
what about cosmoline?
We have this stuff at work like cosmoline. Made by CRC called SP-400. Its corrosion inhibitor and does work. We spray it on shafts, sprockets that come out of the machine shop and stored for future use.
But taking it off is a pain. Use Scotts Brite pads and PB Blaster.
I would no use it on engine parts.
Old 02-17-2025, 06:10 PM
turbo69bird's Avatar
Originally Posted by dhcarguy View Post
Yes, WD40 is what it was made for. The military needed something to stop stored munitions from rusting. It took the company at the time 40 tries to come up with a successful formula, thus the name WD40
I would disagree. You will
Never see anyone use WD 40 on aircraft that sit . Corrosion X is what the aircraft community and boating use. Or aeroshield by Boeing. On products that move you won’t see Wd 40 either because it pulls in debris.
CorrosionX Corrosion Technologies 90102 (16 oz aerosol) – Multi-Purpose Lubricant, Penetrant, Rust and Corrosion Preventative | Industrial Strength | Marine Grade | Cleans Lubricates Protects
https://www.amazon.com/BOESHIELD-Cor.../dp/B0BWWJJVLQ
For items that move I’d use LPS
https://shop.boeing.com/aviation-supply/p/00116=73
960 HP @ 11 psi, 9.70 at 146.
Old 02-17-2025, 06:20 PM
JB Eng Wis JB Eng Wis is offline
AMSOIL MP HD = Amsoil heavy duty metal protector is what I use for crankshafts and stuff.
ZEPRESERVE is what i used to get... very sticky.... not sure if its still available.
And let’s not forget how manufacturers stored parts when our Pontiac’s were made - cosmoline !
https://www.cosmolinedirect.com/
Old 02-17-2025, 06:22 PM
i82much's Avatar
i82much i82much is offline
i have not used cosmoline, just heard it was very effective. like something you would use if you were a prepper and wanted to bury a rifle so you could use it 50 years from now..
i am not a huge fan of hard work so it sounds like removing cosmoline is not for me. thanks for the info!
Old 02-17-2025, 06:27 PM
Nobuddy Nobuddy is offline
Liberal coat of LPS 3 for storage. Then bag it and something to keep mice away.
The Following User Says Thank You to Nobuddy For This Useful Post:
Old 02-17-2025, 07:05 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Would the project causing you to put this away be a 72 by chance 67
Old 02-17-2025, 08:03 PM
Sirrotica's Avatar
When I was in high school I worked part time at a Datsun dealer and I used to help cleaning the cars that were shipped from Japan by boat. They used cosmoline as a protectorate, especially over the chrome. All the things we tried nothing worked well for cutting it except elbow grease. Fine steel wool and a lot of scrubbing with solvents, but we never ran across anything that really dissolved it.
We tried, diesel/kerosene, gasoline, lacquer thinner, enamel reducer, and some I can't recall off the top of my head, none would cut into it. My father worked at the Datsun dealer also, and he was in Pearl Harbor during the second WW, he had the same trouble when he worked in the motor pool over there getting it off of metal parts.
I would never use it because of the difficulty removing it. It is really difficult to remove once it dries.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 02-18-2025, 07:20 AM
67Lemons 67Lemons is offline
Quite possibly Joe
Old 02-18-2025, 05:59 PM
ponchjoe's Avatar
Originally Posted by 67Lemons View Post
Quite possibly Joe
Congrats! Post it up or send me some pics and info.
Old 02-18-2025, 08:57 PM
As soon as it’s here I’ll be sure to post it in the 70-72 section, comes with full documentation but I purchased the PHS package as well.
The Following User Says Thank You to 67Lemons For This Useful Post:
Old 02-24-2025, 09:51 PM
NeighborsComplaint's Avatar
Just my $.02 but I stored my fully machined 455 block, heads and crank on-end in 3 separate garbage bags on the garage floor for 2 years. I sprayed the liberally with WD40 on all surfaces, vacuumed the bags and sealed them with zip ties. Not a spec of rest when I was ready to assemble.
Triple Black 1971 GTO
The Following 2 Users Say Thank You to NeighborsComplaint For This Useful Post:
