Old 03-17-2025, 11:15 AM
Schurkey Schurkey is offline
Originally Posted by 64speed View Post
Serious question. If oil filled gauges are not to be trusted
Originally Posted by Schurkey View Post
LIQUID-FILLED fuel pressure gauges are NOT TO BE TRUSTED...
...UNLESS you burp the gauge at every temperature change.
Either pop the rubber plug at every temp change (engine compartment cold vs. hot.) or cut the nipple so the gauge can vent.
then what brand non oil filled gauge doesn’t just bounce around giving you no steady reading at all? I had a Mr Gasket and a Summit gauge before this one and they all just swung around wildly.
Engine-driven fuel pumps supply fuel in pulses. A non-dampened gauge will react to those pulses by showing the true pressure--which will NOT be steady.
Liquid-filling dampens the gauge. There are other ways to dampen gauges beyond liquid-filling them.
Originally Posted by 78w72 View Post
Weird, had my dry summit gauge in use for 10+ years, zero bouncing or heat related high readings.
Apparently a dampened gauge but not liquid-filled.
Old 03-17-2025, 11:24 AM
78w72 78w72 is offline
Just a standard budget priced dry gauge, doesnt say dampened in the specs.
It is connected to the regulator's gauge port, not sure if a regulator dampens the gauge any, but had same gauge plumbed directly in the fuel line about 3-4" from the carb before I got the regulator and it was also steady with no bouncing.
