| Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
https://ebay.us/m/yRBhgc
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
A mirrored GTX3584RS billet point milled twins configuration with 1.01 V-band https://ebay.us/m/wlI3qu
What's making you look at these over what I sent you?
My Half AN Injun..... |
| The Following User Says Thank You to charlie66 For This Useful Post: | ||
Only looking at these for the simplicity of a v-band vs a T4 mount. If I can get the guy to package the turbos you suggested with a v-band exhaust housing, I’m buying them. If he can’t I’ll probably just buy the T4 version.
Oh, I see. I wasn't following what you meant. Yeah, having the v-band there gives you a lot of universal options .. I've never had one set up like that before. Would be a lot easier to take it off and on that's for sure .. Hopefully he can get you that option ..
I think it is. I messaged the seller but haven't gotten a response yet...
The seller said yes its 2 turbos for that price
Did you pull the trigger yet?
I was actually just about to. Are you trying to stop me or encourage me?
While looking I just saw these GTX3582rs turbos. From what I can tell they are very similar to the GTX3584rs but are a little bit smaller and have a 10 blade turbine instead of a 9 blade. Not sure what you think of the different turbine? Probably splitting hairs at this point since they are pretty close in size. Opinion? https://ebay.us/m/hsW0Dy
From what I've read these compressor wheels are quite a bit larger than a normal gen 1 3582.
-Fit Vehicle: Universal turbo for performance use, racing car etc. -Fit engine displacement 4-10L Up to 1700HP GEN2 Point Milled Compressor Wheel with 65.7mm Inducer 82.6mm Exducer GEN2 Anti-Surged Compressor Cover with 0.72A/R, 4" Inlet and 2.5" Outlet Ceramic Dual Ball Bearing System Turbo GEN2 10 Blades Turbine Wheel with 62.3mm Inducer 68mm Exducer Turbine Housing: A/R 0.83, Dual Vband, 1.01 is also available. I may just go with the GTX3584RS's so I have some room to grow... this is a harder decision than I thought it would be. I don't want to make a mistake
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ Last edited by R 70 Judge; 06-20-2025 at 01:04 PM. |
The 84 turbine will make more power
Stainless headers is having 20% off from now though Black Friday if anyone was thinking of purchasing headers.
https://www.stainlessheaders.com/i-3...tegory:1390481
| The Following User Says Thank You to R 70 Judge For This Useful Post: | ||
im finally mocking my car up. I did go with the 3'' upgrade, however, with atleast an IA2, the casting lugs need to be ground down to allow the manifold to bolt to the head on each side. Ill probably start a build thread in the next few weeks, now that the turbo is here and the car is on the lift.
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
#38
what turbo did you get?
#39
92/103 1.58 ar vsr should get it to the chassis cert
#40
nice, good luck with your build. Ill look for your build thread to follow along.
