I don't have an opinion on Lucas break-in oil BUT, I would try another break-in oil to eliminate that varible! JMHO
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
Melling SPC-8, Crower Cam saver lifters, 1.65 roller rockers. Broke in with Lucas 30W and slathered the cam in Break in Lube. About 3000 mi on her now, all seems well. I do have 1 lifter that bleeds down more than the others, depending if engine stops with that valve open. Takes a few seconds for the clacking to stop. But all puhsrods rotate. Engine is very strong. Even with 3.08 rears, 2400 stall, Easilly light the 275 40 18 Nitto 555 on the rear |
When Mike made his post about turning your mocked up engine over by hand with cam and lifters without lube and looking for lifter rotation......... that seems to be the way to go from here on out.
After having 2 HFT cams with issues on separate lobes, I wouldn’t consider using another HFT cam in this engine unless the cam was Nitrided. I think Paul K may have a Nitrided Crower 60919 floating around yet in his collection, see if he still has it, put the Crower cam savers on it and get back to enjoying your car.
If I were to do an FT cam, I’d check it as indicated for slope / all lifters rotate before nitriding it. Would suck to have that done and still have a cam that doesn’t rotate lifters.
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
A Nitrided cam makes the surface of the lobes much tougher and doesn’t allow the taper to be taken off of the camshaft during the break in very easily even when some lifters do not spin all that well at first. It helps mate the lifters to the cam lobes and will not remove much taper on the cam from the break in. |
| The Following User Says Thank You to Jay S For This Useful Post: | ||
