Wow! I see that you have all the RAIV goodies already! I think they would be perfect in a '69 Firebird 400 clone! That combo would be 700 - 800 lbs. lighter than the GP alone in race weight, so 0.7 - 0.8 sec. quicker by weight savings.
Hopefully you have the D-port long branch manifolds for the GP. My brother built and dyno'd a '69 428HO engine (4-speed car) and with 10.5 to 1 compression and a Summit 2801 cam made 425 hp and 500 lb-ft torque, so would move a 4100 lb GP down the quarter mile in the mid-13's with ease. If I recall correctly, he needed to use flat top pistons (or less dish) to get the compression up with the 62 heads since their chambers cc's at 72 after resurfacing. Dennis |
| The Following User Says Thank You to SD455DJ For This Useful Post: | ||
Dennis |
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
| The Following User Says Thank You to ta man For This Useful Post: | ||
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
I do not think that you will need much cam to run low-mid 13's. You will want as much lift as you can run to take advantage of the round port heads. Not exactly apples to apples, but here is what I used to run in my '70 Grand Prix: 455 +0.030", 4X small chamber heads unported but improved valve job and Ferrea valves, Q-jet, Edelbrock RPM intake, Ultradyne 223/231 .463/.485 110LSA hydraulic flat tappet cam, GTO-style RAIII exhaust manifolds, 2.5" full length, mandrel exhaust with x-pipe, TH400, 13" converter, 3.42 rear. That combo ran consistent 13.00 in 106-degree heat with fuel starvation at the top end. My car is an a/c car, full trim, spare in the trunk, with no lightening done. Times were with 28" MT et-streets.
'70 GP Model J 467 Butler ported Edelbrock D-ports Torker II intake with Holley Sniper 2 CompCams 236/242 hydraulic roller Tribal Tubes tri-y headers full 3" stainless exhaust TH400, 3.50 9" CurrieTrac, 245/35-20 Front, 275/35-20 Rear |
Dennis |
What's it run now with all the changes in your signature?
Chris D 69 GTO Liberty Blue/dark blue T400, 9" w 3.50s, 3905lbs 461, 850 Holley, T2, KRE 310s, Comp HR 236/242D .572/.594L, RA manifolds, 11.53@114, 1.55/60 The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, Howard HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60' |
His brother does amazing work such a gorgeous car and rare!
Haven't gotten it to the track yet, but it has significantly more power, especially 3500 rpm and beyond. Will report when I do.
| The Following User Says Thank You to Sprocket For This Useful Post: | ||
Without a doubt, Rich is a master at his craft!
Dennis |
