I agree that like you posted , you shot yourself in the foot either way those 3.7 gears and only that size cam.
The motor is reving thru the motors torque cradle too fast.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 07-21-2025 at 05:17 PM. |
| The Following 2 Users Say Thank You to steve25 For This Useful Post: | ||
Hopefully that worked. This was the first (engine dyno) run. Did a little better in the next few runs, HP topped at 5,200 |
See above
MT Street Radial Pro 275/60/15 Trying to Launch just off idle, say 1,200 |
Gotcha E but......
My question was for details on Steve's 1.5s 60ft. If he's running a 4200 stall converter he's most likely not doing an idle stomp and flash and he was on slicks so that gives him an edge over Radial Pros but some comparison. Since you're 485hp and 590tq you got a nice 12 sitting in there for sure even at say 4000lbs.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
| The Following User Says Thank You to GOAT8U2 For This Useful Post: | ||
Could it be possible he should re'visit jetting ? I am not implying gearing effects jetting but more RPM'S means more air pumping and if fuel delivery or A/F ratio is marginal to start with then it would be aggravated with more gear?
Secondary air flaps fully opening ? = top end extension Qjet dashpot functioning properly not leaking? The 60" loss seems to me shouldn't be happening with full traction and .4 gear change
........... The More You Follow The Herd The Less You Can Be In The Lead .......... Last edited by Formulas; 07-22-2025 at 07:19 AM. |
The DYNO power says 10's. Go back to 3.31:1 posi. See signature. There must be a fuel problem (maybe the timing backed-off?).
Get a fuel psi gauge. I missed top end mph?
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
| The Following User Says Thank You to Half-Inch Stud For This Useful Post: | ||
My top MPH went from about 108 last year to about 104 this year. This carburetor was rebuilt by cliff, and I’ve had zero problems with it, I’m pretty sure everything is opening properly, and I have verified the full plates open when foot on the floor. again, I know there are thousand things that could be wrong with an engine, but I think my case is simple because I’m only comparing where I was last year, to where I am now with the gearing change. At least that’s what I think. I have the Rob Mick 550 hp fuel pump.
| The Following User Says Thank You to ebartone For This Useful Post: | ||
I like the signature, actually that’s pretty helpful. It gives me hope! 😁
You need to video rear tires at the track to see if you're spinning. When I was setting my car up my 60 went from 1.70s to 1.90s. New converter and trans and it went down in the 1.60s.
Chris D 69 GTO Liberty Blue/dark blue T400, 9" w 3.50s, 3905lbs 461, 850 Holley, T2, KRE 310s, Comp HR 236/242D .572/.594L, RA manifolds, 11.53@114, 1.55/60 The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, Howard HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60' |
| The Following User Says Thank You to OCMDGTO For This Useful Post: | ||
I talked to ebartone earlier today and does anyone think this air filter could be an issue?
https://www.summitracing.com/parts/edl-43662
72 Luxury Lemans nicely optioned ![]() Best so far 12.40 Milan Dragway 2025 I am the Thread Killer! |
| The Following 2 Users Say Thank You to indymanjoe For This Useful Post: | ||
For interest only....
Your 1/4 ET is 11.59 seconds and 117.61 MPH Using vehicle weight of 3900 pounds and HP of 495 http://www.wallaceracing.com/et-hp-mph.php .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
| The Following User Says Thank You to Steve C. For This Useful Post: | ||
I didn't see in any of your posts where you mentioned your fuel system or your fuel pressure. You HAVE TO have an adequate volume of fuel to a Q-jet.
| The Following 2 Users Say Thank You to 65 Lamnas For This Useful Post: | ||
Thanks, yes Rob Mc pump at 7 psi.
I guess I should have worded it differently….
What is your fuel pressure during a pass? |
#38
I don’t have a way to know that, however, I can tell you that there is no feeling of starving for fuel, no stumbling, etc. but I do not have a fuel pressure gauge that I can monitor while I’m making a pass.
#39
To lose 2/10s in 60ft. and lose 4 mph in the 1/4 mile is a lot . You’ve lost it on both ends. Hard to believe only going from a 3.36 gear to a 3.70 would affect 60 ft so much and to blame it all on the gear change. And you went with a taller tire which would have cancelled out some of that gear change. Something else has to be going on here. Is that new rear end robbing horsepower compared to the other rear?
Also you might not feel a complete loss of power at the other end but still be running out of fuel. For the heck of it you can hook up a temporary fuel pressure gauge to see if you’re dipping below 4 psi or so at the other end. Not saying that’s your problem, but it’s always nice to know that information. They say going from a c4 trans to a c6 robs about 20-30 hp just because of the internals.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.45 @ 88.1 mph on slippery street tires.Bad 2.19 60ft.Owned since 86' Last edited by scott70; 07-23-2025 at 07:44 AM. |
#40
Thank you, Scott, and everyone else for the ideas. I do agree with your post, though, it does seem to be a lot just to blame on a gear change. I’m gonna work through a few things for the rest of the summer such as finding a way to measure fuel pressure, and changing out this Air filter as Joe suggested. A few other things as well, thank you everyone for the tips! I really appreciate it.
