At sea level, I would bet I make peak power with more like 32-33 degrees of total timing.
So i was looking at the cables the positive cable is tiny compared to the ground cable plus I'll change the starter. The battery doesn't look old but it's only a 700 cca.
71 Lemans Sport. 72 Lemans Sport. RIP 75 Grandville Convertible. |
I had same problem with my 63,and 421 in late 60s.i go out where guys were street racing stop the car.Short time tried starting it,nope good battery. Cooled off started right up.The starter bushings were egg shaped. Then I learned how to install new bushings. No problems then.
This might be my problem?
That’s a certainty!
trash that old starter and put a mini-starter in with at least 2 awg cables on both the pos and neg posts. I use 1/0 gauge in mine.
I bought a rebuilt starter and put 2 gauge cables on.
Wow that's a rough starter, you got your money out of that thing. LOL
14.2 AFR idle here, roughly 22 degrees timing, don't need to get greedy and burn up valves and also we're assuming each cylinder is getting the proper air and fuel which is never the case, rather error slightly rich than lean.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
