GT |
| The Following User Says Thank You to blueghoast For This Useful Post: | ||
Since I have not seen this posted in a while…
EHTTFMF! Or should it be PKTTFMF? |
Hah! True story! Not sure about the latter though
if i can just get it to running with any motor combo at this point id be set. |
It'll give you momentum... I've always said I'd rather be a half second slower and running than not be running at all.
| The Following 2 Users Say Thank You to PAUL K For This Useful Post: | ||
I have a couple mild engines here waiting for projects I've got. GT |
So true Paul. But hard to try doing!
Lost your # months ago last phn fried. Msg you possible package swap Tossing in towel go faster then 9s.
ive got a couple i can throw in it, ill throw this 871 on one these stock blocks and let it rip lol. all my py forums bargain shopping over the years took care of that lol. my biggest problem now is work schedule and other projects....seems my pontiac finds the back burner on time. ill get there though. |
When I first seen this thread I thought they were Wide Ports by the numbers. Not sure I have seen any better numbers out of a std port E heads.
Nice work Paul. They have a bit better numbers than my High Ports with some bowl work. You should have plenty of people getting in line for a set of these. Affordable power. |
| The Following User Says Thank You to Dragncar For This Useful Post: | ||
